Activity › Forums › VEGAS Pro › Sony vegas black and white
  • Sony vegas black and white
    Posted by Giulia Gira on August 26, 2010 at 2:53 pm
    HI there,
    since last time you were really helpful i thought i could use your advices again this time.
    ok, i have a series of clips pretty short. How can i make that effect in which the first of these clips is in black and white and then it gradually change in normal colors through the last clip?
    Thanks a lot as always
    John Rofrano replied 16 years, 1 month ago 2 Members · 1 Reply
  • John Rofrano
    August 26, 2010 at 7:09 pm
    Add the Black & White filter and Keyframe the amount over time. If you want it to last over several clips you can place them on a separate track and add the filter to the track. Otherwise you can add it to each event and only keyframe the event where the change to color takes place.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
