Activity Forums VEGAS Pro Sony Vegas 9.0 Render Settings
  • Sony Vegas 9.0 Render Settings
    Posted by Grant Pohl on August 9, 2011 at 5:23 am
    I’ve captured a bunch of video onto my pc and am now stuck at the rendering settings. There’s many options and I can’t seem to find any valuable info on the internet about what the different options mean. I want to get the kind of quality where a 2 hour video is only about 1gb, not 20gb. I’ve read some of Sony’s documentation but cannot find what I’m looking for. The last render I did looked like this when I look at the video’s properties:
    720 x 480
    1501kbps
    pcm
    29 frames/second
    7913 kbps
    24 bit
    ffds
    The video was approximately 2 hours long and 15gb in size.
    What settings should I use so that my video ends up like a normal, good quality movie that isn’t so big?
    thanks
    Mike Kujbida replied 15 years ago 3 Members · 4 Replies
  • Mike Thomas ii
    August 9, 2011 at 9:04 am
    There are many ways to skin a cat and even more ways to render in Vegas.
    You could render out using Save As…MainConcept AVC/ACC (.mp4) and then change the template settings for frame size and bit rate (which will determine the overall file size).
    I render most of my files in DivX, so I can play them on my Xbox360 and burn them to a DVD to play in a compatible DivX-DVD player.
    The DivX Converter (free download https://www.divx.com/en/software/divx-plus/converter) has a bit rate calculator, so you can set the exact file size if you wish. The converter can be used as standalone program or through Vegas in the ‘Video for Windows (*.avi) render options, then you change the template, Custom > Video format to DivX Codec > Configure…select your profile.
    If I am doing a straight conversion with no editing or effects, I use the DivX standalone program, it seems to convert faster than in Vegas.
  • Grant Pohl
    August 11, 2011 at 12:56 am
    Hi, I downloaded and tried to use Divx, but when I started rendering, it stopped and gave me an error message about the codec. So I tried to use another program instead of Vegas to render. The other programmed rendered it, but the files still seem to be coming out a little bigger than I want. Most movies seem to be about 700mb. How do I get an .avi video to be about that size? thanks
  • Mike Thomas ii
    August 11, 2011 at 1:18 am
    Here is a list of free bitrate calculators that should help you set file sizes.
    https://www.videohelp.com/tools/sections/bitrate-calculators
    And for Windows Media files (.wmv) you go here https://alexzambelli.com/WMV/WMVBitCalc.html
  • Mike Kujbida
    August 11, 2011 at 1:33 am
    [Grant Pohl] “How do I get an .avi video to be about that size?”
    If the program you’re using will let you, lowering the bitrate is the only way to reduce the size.
