Activity Forums VEGAS Pro Sony Vegas 9.0 Crash Issue
  • Sony Vegas 9.0 Crash Issue
    Posted by Chelsea Volz on August 20, 2011 at 5:40 am
    Hello all,
    So, I recently started having a litle issue with Sony Vegas. I have quite a few projects that use a certain m4v clip and recently, when attempting to open (any of) these projects to work on them, Sony Vegas crashes before loading the project. It gives me the option to “send” the issue to SV and this is the stack dump:
    Extra Information
    File: C:UsersChels BellsAppDataLocalSonyVegas Pro9.0dx_video_grovel_x64.log
    File: C:UsersChels BellsAppDataLocalSonyVegas Pro9.0dx_grovel_x64.log
    File: E:Projects in ProgressCollabsThe O.C. collab.veg.bak
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 9.0 (Build 562) 64-bit
    Problem: Unmanaged Exception (0xc0000005)
    Fault Module: C:Program FilesSonyVegas Pro 9.0FileIO Plug-Insmcmp4plugmch264dec.dll
    Fault Address: 0x00000000068880A7
    Fault Offset: 0x00000000000080A7
    Fault Process Details
    Process Path: C:Program FilesSonyVegas Pro 9.0x86FileIOSurrogate.exe
    Process Version: 1.0.0.1
    Process Description: Sony File Interface Surrogate (not visi
    Is there anything I can do? I’ve already tried opening the bak file and I’m currently attempting to convert the format to MJPEG, but even if I convert it, how would I open the file to change out the clips?
    Any help is greatly appreciated.
    My sony vegas is 9.0 64 bit.
    I have an 8-core Mac Pro with 16GB of RAM and I run Windows via Boot Camp.
    Thanks in advance,
    Chelsea
    Stephen Mann replied 15 years, 1 month ago 2 Members · 1 Reply
  • Stephen Mann
    August 20, 2011 at 4:42 pm
    An “unmanaged exception” Windows error is almost always a driver issue. But if you have identified the offending piece of media, and replaced it with a transcoded copy, then just delete the old one. The next time you start the Vegas project, it will complain that it can’t find the media. You just provide the new media name.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
