Sony Vegas 8 > Quicktime Pro Import Issue
Posted by Daniel Fluri on May 8, 2008 at 12:15 pmHello everyone, i’m new here and need some support:
I use Sony Vegas Movie Studio Platinum 8.0 testversion.
I want to open a file with Quicktime.mp4 (MPEG-4 Movie) and use for this Quicktime PRO V7.1.5 what is the newest version of Quicktime.
>>> Sony Vegas failure: Popup with information that only Quicktime files from version 7.1.6 and above can be imported. But this version doesen’t exist on Windows. I use Windows Vista Ultimate 32bit.
Any help?
Thx
No Vegas replied 15 years, 1 month ago 4 Members · 7 Replies -
Daniel Fluri
May 8, 2008 at 2:07 pmHello
I found the problem & solution: Quicktime updater doesen’t work, i had to reinstall and download 7.4.5.
Now it works.
Plz delete this thread.
Greetings
Douglas Spotted eagle
May 8, 2008 at 2:39 pmQuicktime 7.2 is indeed available for Windows, it’s installed on most of our machines. Be sure you’ve installed the entire app, not just the read components.
Douglas Spotted Eagle
VASSTCertified Sony Vegas Trainer
Aerial Camera/Instructor -
Daniel Fluri
May 8, 2008 at 8:44 pmHi
Thx for your support, after reinstalling i finaly got 7.5.4 version, now it works.
Greetings
Jeff Miller
December 7, 2008 at 11:31 amI have the same problem, I can’t import QuickTime.mov Files into Vegas Pro 8.
I’m running Windows XP service 2. I have installed the latest QuickTime 7.55 Version for Windows and still can’t import into vegas pro 8. I receive error message telling me to update.
What did you mean ??? — Be sure you’ve installed the entire app, not just the read components. — Please explain…
How I installed the latest Quicktime 7.55 was that I downloaded it to my desktop and installed it from there. Isn’t that the correct way to do it??? Isn’t that installing it as full install??? Am I missing something??? Can you Please explain??? Thank You.
December 7, 2008 at 3:42 pmWhat codec is inside the .mov container?
Jeff Miller
December 7, 2008 at 7:54 pmHi Douglas,
Rendering as QuickTime.mov container I’ve tried it with PhotoJpeg, PNG, Video, Sorenson Video, And also with None.
I get the following error message:
The Sony QuickTime plug-in was not able to initialize the QuickTime Components on your system. It appears that QuickTime for Windows is not properly installed.
QuickTime files cannot be read or written without a full installation of the QuickTime Version 7.1.6 or greater components, including the authoring components.I’ve downloaded for Windows QuickTime 7.55 Version without iTunes to my desktop and installed it from there. I’m assuming that that is a Full Installation Download??? But I’m not sure??? Not sure what to try next???
No Vegas
August 23, 2011 at 6:45 amI’ve had the same issue as well. If I install the latest QuickTime my MOV files are BLACK when imported into Sony Vegas 8 Pro in Windows XP sp3.
I had to uninstall the new quicktime and find an earlier version of quicktime, and it worked. Something with the new version of quicktime Sony Vegas Pro 8 doesn’t like because it works fine on Sony Vegas Pro 10 with the latest version of QT.
