Activity Forums VEGAS Pro Sony Vegas 6.0 – burning a dvd
  • Sony Vegas 6.0 – burning a dvd
    Posted by Pamela Chan on January 11, 2008 at 1:11 am
    I have Sony Vegas 6.0 and I have tried several times to burn a movie I edited onto a DVD. I have gone up to the step where I prepare it in DVD Architect. When I try to burn it using my external burner, it says to insert a write-able DVD. However, I have tried -R, -RW, and +RW.
    Then when I try to use my internal burner, it says that it is “retrieving media info” but this takes several hours without doing anything.
    What am I doing wrong?
    Jerry Waters replied 18 years, 8 months ago 3 Members · 2 Replies
  • Don Bloom
    January 11, 2008 at 4:10 am
    Let’s look at the internal burner.
    When you say you prepare it in DVDA do you mean you have already encoded to MPEG or is it still in AVI form?
    If you have not already done so then render to MPEG in Vegas using the appropriate bitrate for the size video you have OR render the project to AVI in Vegas and bring the AVI into DVDA and FIT TO DISC in DVDA. You can still put in chapters if you wish, customize the menus but DVDA does the work or converting. Once the project is in proper MPREG format THEN you drag the MPEG to the project overview or into the timeline or onto the menu in DVDA and move on from there.
    That should take care of retriving media info whatever that means.
    Don
  • Jerry Waters
    January 11, 2008 at 4:56 am
    I wrote an answer to a person with an audio problem today so I’ll just cut and paste this from that and hope it helps.
    “The usual or recommended way to do a DVD out of Vegas is render two separate files – one is mpg2 (and the DEFAULT setting in Vegas is without audio – have to check a box to get audio with it) and the second file is AC3 which is matching audio (render the same area). Both files should have the same name and when you go into DVDA and give it the video file name it will pick up the audio automatically. Then DVDA processes that. DVDA can “prepare and burn” or just “prepare” and most of the experts recommend just use the “prepare” in DVDA, creating the files to disc and then burning with Nero or some other burner program. It is also recommended that you encode in Vegas – NEVER DVDA – because the render engine in Vegas is much better.”
    If you follow those steps you should have no problems. If you do have a problem, give more details on how you processed, the burn programs used and steps taken.
    JerryW
