sony vegas
Posted by Mads Danhgåd on March 15, 2010 at 12:45 pmi just downloaded the sony vegas 9 demo and i got some tapes i want to capture.
but the problem is that it says please connect a device, and that i have did.
i have read some other topics on same issue but nothing seems to help me.im using a DSR-PD100 but i wont recognize the device:-(
any help will be apriciated.
thanks in advance.
Mike Kujbida replied 16 years, 6 months ago 3 Members · 8 Replies -
Mads Danhgåd
March 17, 2010 at 11:54 amyes im filming to the tape.
and i play the tape when i try to syncronize. -
Mike Kujbida
March 17, 2010 at 1:19 pmThe PD 100 is a DVCAM camcorder so Vegas should see it if you hooked it up with a firewire cable and use the built-in video capture utility.
Mark Mccormack
March 18, 2010 at 1:14 amYou don’t need your camera playing, just got to capture choose dv, then your camera should sync to your computer.
Mads Danhgåd
March 18, 2010 at 11:43 amthats exactly what i do but no luck… it just keep saying please connect device
Mike Kujbida
March 18, 2010 at 3:40 pmPlease give us a detailed step-by-step list of everything you’re doing to connect the camcorder to Vegas.
Mads Danhgåd
March 23, 2010 at 4:14 pmi put the camcorder to the pc via firewire to DV on the cam.
the i set it on VTR on the power option, nothing happens. no usb connected sound or nothing.
then i open vegas and push capture.
the i use the first option DV and then it says please connect device.
i hope this is good enough a description..thanks in advaced
Mike Kujbida
March 23, 2010 at 5:51 pmThose are the correct steps so I’m not sure why it isn’t working for you.
Go through the manual for the camcorder and make sure that there isn’t a special setting that you’ve overlooked.
Do you have another camcorder that you can try (to confirm that capture does indeed work properly)?
