Activity Forums VEGAS Pro Sony Vegas 14 Video Import Problem
  • Sony Vegas 14 Video Import Problem
    Posted by Christian King on January 22, 2018 at 7:27 pm
    Hi
    Everytime I import a gameplay video recorded with NVIDIA Shadowplay it is cropping half the clip as you can see in the preview window and it is also changing the resolution of the project which was set at 1920×1080 to 1280×1024
    NVIDIA Shadowplay clip is: 1920×1080 @ 60FPS
    I have never had this issue before it has only been this week I have always imported my NVIDIA Shadowplay clips without any problems also if you watch the clips they are fine and have the whole screen.
    Here is a image of sony vegas. https://image.ibb.co/hdVA7R/sonyvegas.jpg
    Tyler Fowle replied 8 years, 6 months ago 3 Members · 3 Replies
  • Marco Baer
    January 22, 2018 at 8:52 pm
    Unfortunately ShadowPlay use to record non-standard video files. One thing often works is re-muxing such files before importing into Vegas Pro.
  • Christian King
    January 22, 2018 at 9:49 pm
    But it has always worked for me up until now and I tried again today recorded 1 clip that imported find recorded next clip no settings changed and its the same thing again
  • Tyler Fowle
    February 7, 2018 at 10:59 pm
    When you import the video, does it ask to match the media video settings? If so, try selecting “yes”. If not, go to File > Properties… and select this button:
    And choose the same video file you used.
