Activity Forums VEGAS Pro Sony Vegas 14 Crashes while rendering
  • Sony Vegas 14 Crashes while rendering
    Posted by Khanh Luong on June 26, 2017 at 2:12 am
    I recently upgraded to SV14, and ive been working on a really heavy project. Usually at like 95% when I’m almost done rendering it will crash. I’ve tried all the fixes on youtube and nothing has worked. I’ve never had this many crashes on 13 before and I would like to know the fix. The only reason I’m even staying on 14 right now is because my project I’ve spent 10+ hours editing is on here and I cant run it on 13.
    Here’s what it says:
    Problem Description
    Application Name: VEGAS Pro
    Application Version: Version 14.0 (Build 161) 64-bit
    Problem: Unmanaged Exception (0xc0000005)
    Fault Module: C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9247_none_08e394a1a83e212f\MSVCR90.dll
    Fault Address: 0x00000000754AE293
    Fault Offset: 0x000000000001E293
    Fault Process Details
    Process Path: C:\Program Files\VEGAS\VEGAS Pro 14.0\vegas140.exe
    Process Version: Version 14.0 (Build 161) 64-bit
    Process Description: VEGAS Pro
    Process Image Date: 2016-09-13 (Tue Sep 13) 20:47:24
    Shunichi Daido replied 9 years, 2 months ago 2 Members · 1 Reply
