Activity Forums VEGAS Pro Sony Vegas (13) not rendering High contrast properly
  • Sony Vegas (13) not rendering High contrast properly
    Posted by Ozren Gospod on May 12, 2020 at 10:26 am
    Hello all,hope you’ve been doing good. Found some articles about the problem that I had yet none helped so I thought I might as well post it here.
    So the story goes, the preview of my video doesn’t match the rendered result,varying in the contrast/saturation of it.
    (this one above is the one it’s supposed to be looking,shown in the preview)
    (and the result,both in GOM player and VLC)
    I messed around with layers on video FX, didn’t work ; put the quality to Best(Full), didn’t work. Help.
    Francois Pénzes replied 6 years, 4 months ago 3 Members · 6 Replies
  • Steve Rhoden
    May 13, 2020 at 1:22 am
    Which filter are you actually applying to that event?
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • Ozren Gospod
    May 14, 2020 at 10:37 pm
  • Francois Pénzes
    May 15, 2020 at 12:43 am
    Hi Ozren
    Let me try something mad here: Are you rendering at 32 bit Floating Point (Full Range) per chance ? (That’s Pixel Format in Project Properties)
    Cheers !
    PC Win 10 Pro 64-bit 16gb
    Ryzen 9 3900X 12 Core 4.60GHz
    Radeon RX 5700 XT
    Cameras: Canon XF305 + Canon XH-A1 and a bunch of others
    Vegas Pro 16, User since Vegas 3.0
    \’\’When the cutting stops, the editing begins…\’\’
  • Ozren Gospod
    May 16, 2020 at 5:06 pm
    Yes, I have render with that setting and it happened what happened. BUT with changing it to 8-bit the problem vanished! Now I’m worrying the rest of the video will be lesser quality cause of that
  • Ozren Gospod
    May 16, 2020 at 5:17 pm
    Got it. Rendered the original at 8-bit and then rendered the rendered video at 32-bit floating point (video levels) and raised the aspect ratio to 1,3333. Then I matched it on the rendering template Internet HD 1080 and it’s perfectly fine. Tho I’m wondering, does changing from 1,0 to 1,3333 pixel aspect ratio change something?
  • Francois Pénzes
    May 16, 2020 at 6:05 pm
    Hi Ozren
    John Rofrano explains it well in this post:
    https://forums.creativecow.net/thread/24/901342#902116
    Cheers !
    Radeon RX 5700 XT
