Activity › Forums › VEGAS Pro › Sony Vegas 13 + GTX 750 TI + CUDA CORES
  • Ricardo Farah
    April 1, 2015 at 8:21 pm
    I don’t think OpenCL have to be something with this. There is a option to use OpenCL too.
    I’m recording from a webcam AND capturing my gameplay via Shadow Play of NVDIA wich i have the options of 30 or 60 FPS. I did not veryfied if the files are actually at 59,(floating something) neither that it would cause such delay on rendering. I will verify that later, but i don’t think it will save as much as if sony vegas got able to use my CUDAs.
    Sorry about the english.
    Intel Core I7-4770
    16 GB RAM(15,9 Usable)
    GeForce Gtx 750 TI
    Asus B85M-E/BR(4Satas R3.0, 2 Satas R2.0)
    SSD Kingston 240GB (System and programs)
    SSD50GB (Temporary area for capture heavy records)
    HD1TB (For all stored Data)
    Webcam Logitech C920
    Happauge Rocket Capture Card
    Windows 8.1 (Always updated)
    Sony Vegas 13
  • Ricardo Farah
    April 1, 2015 at 8:23 pm
    About the link You sent, it would be very interesting if at last my GPU was being used. I’m pretty sure i hasn’t gained any gain on rendering performance afeter upgrading to 16 GB RAM and installing my GPU. Ony games and time line of vegas got upgraded.
    Intel Core I7-4770
    GeForce Gtx 750 TI
    Sony Vegas 13
  • Ricardo Farah
    April 1, 2015 at 8:27 pm
    So it helped….i was testing only without any modifications on the video, just to get the lopping to 5seconds and rendering as to see the time taken.
    I will update later with the gpu jobs.
    Intel Core I7-4770
    GeForce Gtx 750 TI
    Sony Vegas 13
  • Surya Prihadi
    June 6, 2015 at 4:36 pm
    Hi Ricardo,
    I want to share my findings, which I found by accident.
    I know this is an old thread, but I hope you can be assisted.
    I too have a GTX750 Ti, but my primary GPU is GTX 580.
    To cut the story short and for MainConcept AVC GPU assist.
    First you go to here :
    https://www.sonycreativesoftware.com/forums/ShowMessage.asp?ForumID=4&MessageID=904569
    Look at Oldsmoke post on upsizing the OpenCL memory. Use 1,536 is enough.
    You must use NVIDIA driver no newer than 331.65 ( only this 331.65 I tried work ) for the GTX750 Ti to work its GPU for Vegas Pro. However this driver, if you use a software which can read GPU models, will read GTX750 Ti as just a graphic card. Don’t ask me why it is so, me don’t know.
    It is true that Vegas only love Fermi based Nvidia, like GTX570 and GTX580, and with those cards and suitable driver and older Vegas Pro like VP11 or VP12, the GPU assist is fantastic….however, once you use newer Nvidia driver than 331.65, the GPU assist will simply died down to such percentage or speed which will make u pissed.
    GTX 750 Ti is actually Maxwell based GPU ( newest architecture ) and 1 generation down Kepler ones like GTX660Ti or the like, will not work well with Vegas Pro GPU assist….. unlike the 2 generation down Fermi based one GTX 570 or 580. This is why I said I found this out by accident as I would never imagine Maxwell based Nvidia will work on Vegas Pro as well as older Fermi ones.
    I have 2 of GTX980 Vnidia sitting useless now…LOL, because minimum driver is way too new for my GTX580 to use its GPU in Vegas Pro. So driver is very important.
    GTX750 Ti will not throttled itself like a GTX580 would in Vegas Pro, if both are using most suitable Nvidia driver for Vegas Pro. GTX580 is still my choice. However based on my test with 331.65 and that OpenCL memory size increased to 1,536 and Mainconcept AVC…..the 750 Ti can assist up to approx 24% GPU load for GH-4 3840 x 2160 MOV file of 25FPS, choosing CUDA option. If using Sony official test video, that red mercedes covertible, GPU load can be up to 40% for Mainconcept AVC and CPU load 55ish% ( i7 3930K 6 core ). However on XD CAM 1440p x 1080, GTX 750Ti does not assist at all, but a GTX580 will throttle up to 75%.
    My suggestion is to google Oldsmoke ( user name ) in Sony Creative forums.
    He is experiment king.
    This will be good reading too :
    https://www.hyperactivemusic.com/vegaspro/vegaspro.html
    I am in my own dillema too. I love VP because it is so easy to use.
    However with 4K now, I want newer Nvidia card with Display Port and 4K/60Hz ready for video not games, hence I have 2 x GTX980 …BUT newer Nvidia driver kill the GTX580 GPU assist capability, while new GTX980 is useless for Vegas Pro GPU assist hardware wise and will not work with older Nvidia driver software wise. So its bad luck for me … LOL.
    Good luck trying out.
    PS
    If you are using MainConcept very often and heavily relying on it , get a used GTX580, it is worth the investment and it will work with your GTX 750 Ti. If u have both GTX 750 Ti and GTX 580, appoint GTX750 Ti as the card of choice in Vegas Pro ( I place my GTX750 Ti in 1st PCIE slot, nearest to CPU ) and when rendering using MainConcept and CUDA, both will work up to 40% for GTX 750Ti and 50-70%ish for GTX580 and CPU 55%ish. This dual working GPU load, I do not get from my older GTX650 ( Kepler based ), even with older Nvidia driver.
    That Sony red car project, I can do Internet 1080P Mainconcept in 45 seconds and the XDCam one in 47 seconds with i7 3930K 6-core 48GB RAM and only mild overclock by Asus software to 3.5Ghz ( stock is 3.2Ghz ). Remember Nvidia driver 331.65 only and appoint GTX 750 Ti as GPU of choice in Vegas Pro.
    Later….
    SP
  • Jorge Talamantes
    June 7, 2015 at 12:38 am
    Hi, Sony Vegas I known to to work nice only with the 500 series noida Gpu cards
  • Ricardo Farah
    June 8, 2015 at 2:41 pm
    Surya Prihadi I really appreciate Your time for making this post.
    It was indeed old but I still have the same problem. I alread got used with it.
    Latelly i have not the time to record and work on my videos and even less to see try those things as I don’t have sufficient income to work at home yet.
    Also as a gamer, I came plenty use of the SHADOW PLAY functionality that cames with the drivers so I think i can’t do that driver downgrade.
    But I hope this helps somebody out there.
    My only salvation is a workaround from sony it self(a miracle :D)
    But thank You again.
    Intel Core I7-4770
    GeForce Gtx 750 TI
    Sony Vegas 13
Page 2 of 2
