Activity Forums VEGAS Pro Sony vegas 13 crashes when opening
  • Sony vegas 13 crashes when opening
    Posted by Martin Benjamin on August 30, 2015 at 10:31 am
    Since I installed windows 10 sony vegas stops working. I tried reinstalling it but that didn’t work. I uninstalled quicktime as well but that didn’t work either. I hope there is an solution for this.
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 13.0 (Build 453) 64-bit
    Problem: Unmanaged Exception (0xc0000005)
    Fault Module: C:\Program Files\Sony\Vegas Pro 13.0\vegas130.exe
    Fault Address: 0x00007FF78F4AA710
    Fault Offset: 0x000000000081A710
    Fault Process Details
    Process Path: C:\Program Files\Sony\Vegas Pro 13.0\vegas130.exe
    Process Version: Version 13.0 (Build 453) 64-bit
    Process Description: Vegas Pro
    Process Image Date: 2015-06-05 (Fri Jun 05) 14:53:04
    Steve Rhoden replied 11 years ago 4 Members · 5 Replies
  • John Rofrano
    August 30, 2015 at 4:01 pm
    Did you perform an upgrade in place of Windows 10 or a clean install? Upgrade in place is never a good idea but I realize that’s what Microsoft is unfortunately recommending these days. I would try a clean install instead if you can’t solve it any other way.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Steve Rhoden
    August 30, 2015 at 5:09 pm
    If all else fails, try also to update all your drivers (Video card/Audio, etc) Everything…
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • John Rofrano
    August 30, 2015 at 5:27 pm
    [Steve Rhoden] “If all else fails, try also to update all your drivers (Video card/Audio, etc) Everything…”
    Oh yea that reminds me. I had a similar problem when I switched video drivers. Vegas Pro immediately crashed. I had to install the old drivers, tell vegas Pro to disable GPU, install the new drivers, then tell Vegas Pro to enable the GPU. Not fun.
    ~jr
  • Bob Peterson
    August 30, 2015 at 10:01 pm
    Famous last words. “There is absolutely no problem in upgrading to Win 10!” I sympathize. This situation has been discussed in several threads over the last few days. It looks like Win 10 is losing the debate. I do hope you get it sorted out so that everything works again.
  • Steve Rhoden
    August 31, 2015 at 12:51 pm
    Any luck?
