Activity Forums VEGAS Pro Sony Vegas 12/10 will not start renders
  • Sony Vegas 12/10 will not start renders
    Posted by James Davis on March 22, 2013 at 2:53 pm
    Hey guys,
    Recently got Vegas 12 put on my buddies computer, which is brand new and newly built. Everything works fine up until he hits render. At that point, no matter what file format he is rendering from, it acts like it is going to start rendering, but doesnt. It never goes past 1% and the estimated time keeps climbing until you force close the application.
    I have completely uninstalled and wiped out the registry (even by hand) and re installed and it still does not work. I tried putting my copy of 10e on and it won’t render with that either.
    File from format m2ts
    File render format – mp4, avc, wmv (10)
    Any ideas what this could be?
    Dave Osbun replied 13 years, 5 months ago 4 Members · 6 Replies
  • Dave Osbun
    March 22, 2013 at 3:08 pm
    Please list all hardware specs (system drives, where video is stored, render drive, CPU, etc.).
    Dave
  • James Davis
    March 23, 2013 at 2:07 am
    CPU – I7 3770k
    MB – Asrock Extreme4
    Cooled by h100
    GPU – Powercolor 7870 Tahiti LE
    Hdd – 64gb crucial m4 and a 1tb seagate 7200 rpm.
    Video file is on the SSD (the boot drive)
    I had the system running with the hard drive and had vegas installed and working, but when I put it on the SSD, then I it would no longer render.
  • Stephen Mann
    March 23, 2013 at 4:09 am
    You need at least 2X your estimated project size free on your temp folder and your target folder. So if you are making a 4.7Gb DVD file then you need at least 9.4Gb free on both folders.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Bob Peterson
    March 23, 2013 at 6:54 pm
    64 gigs is probably enough for Windows, but I work hard to minimize the space used by applications on my 80 gig SSD. Whenever possible, I install applications to a much larger normal hard drive. Since your trouble began when you moved Vegas to the SSD, move it back to the hard drive.
  • James Davis
    March 23, 2013 at 7:38 pm
    I used a 64 gb for a long time. It has paging file and Hibernation turned off so it has about 30gb worth of space. We are dealing with files under 4gb so It’s not some massive render.
  • Dave Osbun
    March 25, 2013 at 6:25 pm
    The SSD is obviously the cause of the problem since it rendered fine until he switched HDs. Did you make the appropriate BIOS change when you added the SSD? I can’t remember what that change was, but I know that when adding an SSD to an already-configured system that a BIOS change was needed for the SSD to perform properly.
    Dave
    Intel i5 3570K Ivy Bridge 3.40GHz quad core
    Asus P8Z77V-LK
    16gb RAM
    ATI Radeon HD7850 2gb
    Crucial M4 SSD + Seagate Barricuda 7200rpm
    Windows 7 Pro 64
