Activity Forums VEGAS Pro Sony Vegas 12 Plays Audio But Not Video
  • Sony Vegas 12 Plays Audio But Not Video
    Posted by Jayce Ulliac on December 30, 2012 at 3:13 am
    Hey guys,
    so I’ve started a video project and got all of the shooting done however my camera captures in .AVI. I imported them into Vegas so that it was on the timeline however there was no video. After a quick google search I soon found out that Sony Vegas isn’t compatible with .AVI so I converted it into .wmv however there is still no video! I should probably mention that the first thing I did when the video showed up was download this “K-Lite Codec Pack” hoping it would help. Unfortunately, I just got a bunch of errors so I attempted to make sure that it didn’t change anything and I uninstalled it.
    My specs: Windows 7 Home Premium SP1
    AMD FX(tm)-6100 six-core processor 3.30 GHz
    8 GB of RAM
    64-bit
    Jayce Ulliac replied 13 years, 8 months ago 3 Members · 9 Replies
  • 9 Replies
  • Graham Bernard
    December 30, 2012 at 4:15 am
    “After a quick google search I soon found out that Sony Vegas isn’t compatible with .AVI”
    Wrong!
    I’ve been using AVI containers for 12 years in Vegas. It’s what INSIDE the AVI container you’ve got to determine.
    The INTERNET is a great portal for “information”. However, you get incorrectly recieved-wisdom too. Do NOT install any further CODEC packs – STOP!
    Download the free media analyser G-Spot and determine what’s inside that AVI.
    Grazie
    Cameras: Canon XF300 and two elderly XM2s
  • Jayce Ulliac
    December 30, 2012 at 4:25 am
    Well actually I’ve figured out what the problem was but now I don’t know how to fix it. I downloaded the “K-Lite Codec Pack 64-bit” and but the problem was that I had DivX installed before hand. I read that before I install K-lite I’m supposed to delete any other codec packs I have. I deleted all of DivX that I could find and then installed K-Lite again however now nothing is working at all. 🙁 Even with a .WMV file as soon as I attempt to play it Sony Vegas crashes.
  • Aleksey Tarasov
    December 30, 2012 at 5:00 am
    All codec packs are intended for use with video players, not video editors. Uninstall all third-party codecs, reinstall Vegas and try again. If this does not work, use MediaInfo to identify the unknown codec, and then download it and install (or convert your video to the “editable” format)
    Vegasaur.com – Plugins for Sony Vegas Pro
  • Jayce Ulliac
    December 30, 2012 at 5:26 am
    Alright, I did what you said and it still isn’t working however I have something for you guys this time 😀 An error report Yayy!! Here’s the image.
  • Graham Bernard
    December 30, 2012 at 7:49 am
    Why haven’t you attempted to discover what G-Spot could tell you?
    You are also running an earlier version of VP12. Build394 is the latest.
    G
  • Jayce Ulliac
    December 30, 2012 at 7:55 am
    Because it’s any format that I put in crashes instantly when I attempt to play it :/
  • Graham Bernard
    December 30, 2012 at 9:44 am
    Explain?
  • Jayce Ulliac
    December 30, 2012 at 9:06 pm
    So opening up SVP is fine, putting a clip in is also fine. Playing the empty areas (with nothing on them in the timeline) in SVP is fine. However the second I scrub over to any clip of any format and hit play SVP crashes instantly.
  • Jayce Ulliac
    December 30, 2012 at 9:11 pm
    Now it’s not crashing… wierd… I havent done anything but shut off my computer and go to sleep however I’m still getting no video in the preview no matter what I do! Even if I drop in a solid color it doesn’t show up.
    Edit: I updated my video card and now it’s crashing again… :/
