Activity › Forums › VEGAS Pro › Sony Vegas 12 Image Breakup and Pixelation in preview and render
  • John Rofrano
    September 7, 2015 at 11:22 pm
    I’m guessing the problem is with your source video.
    What file format do your source videos use? (AVI. MP4, WMV, etc.)
    What codec do your source videos use? (DivX, Xvid, x264vfw, Fraps, etc.)
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Bill Billson
    September 8, 2015 at 6:30 am
    Here is the codec I am using https://gyazo.com/5c9a3a0fc79c29b421da9b90a301e678
    The footage looks perfectly fine in windows movie maker and the orgiginal .avi file, I just dont know why it started to do this in vegas
  • John Rofrano
    September 8, 2015 at 11:24 am
    [Bill Billson] “Here is the codec I am using”
    OK, that’s the problem. You’re using Xvid and Vegas Pro doesn’t handle Xvid well at all. I recommend that you either use a different codec to capture like M-JPEG or Lagarith with PCM audio or you convert your current Xvid videos to M-JPEG or Lagarith for editing. You can use the free AviDemux 2.5 to make the conversion:
    If you do use AviDemux, make sure that you use 2.5 and not 2.6. Vegas Pro has problems with files created with 2.6.
    ~jr
