Activity › Forums › VEGAS Pro › Sony Vegas 12 hangs for 30 seconds when selected in Windows 10
  • Sony Vegas 12 hangs for 30 seconds when selected in Windows 10
    Posted by Bob Ridge on July 1, 2016 at 5:59 pm
    Hi! I’ve managed to keep most of my workstations from doing the automatic update to Windows 10, except the one that I use most frequently. Ever since it updated, everything works more or less as I’m used to except one thing. Whenever I go from Sony Vegas 12 (build 770) to any other window, even for a few seconds, then go back to Vegas, it takes about 30 seconds before Vegas kicks in & recognizes any of my clicks. It’s become almost unbearable to use for that reason alone. I never realized how frequently I check emails, go on social media, open Explorer windows, etc. This only happens with Vegas and not any other program, including Lightroom & Photoshop. Is this a known issue anyone else has dealt with before? Not finding much in Google.
    Bob Ridge
    i7-3770 3.40GHz
    10 MB RAM
    Windows 10 64-bit
    Brie Clayton replied 7 months, 2 weeks ago 5 Members · 6 Replies
  • Aaron Star
    July 1, 2016 at 7:52 pm
    Do you really only have 10MB or 10GB of RAM? The rule of thumb is 4-8GB of RAM per CPU core.
    Win10 has a ton of back ground processes that make it do all the fancy things like boot fast, contana listening for commands, and other things. It could be with such a low amount of RAM, the system is swapping when you task switch. If you have overly agressive power saving settings, your HDD could be sleeping and that takes time to spin back up.
    10GB is also a strange amount of RAM in the 1st place. I would get a tool like speccy and determine if you have the correct optimal memory speeds for the chipset. Then run:
    Memtest86+ – to check that the memory controller and RAM sticks are 100% error free. The built in WIN10 memory checker is no good.
    Run all Win10 updates, and make sure there are updates waiting for a restart, re-start as many times as needed.
    Perform a SFC /scannow from an admin command prompt, and make sure there are no errors there.
    With the right amount of RAM, Vegas should task switch just as fast as say Word, to Chrome. Pausing beyond that, I would look at Windows Process monitor and see what the system is doing during the pause. Bad network drive mapping, non-responsive DNS server, or errors on HDD media could be causing a timeout situation when reading media for thumbnails.
  • Larry Brewer
    March 12, 2017 at 6:55 pm
    Bob, I’m pretty sure that there is a setting to remedy that problem of Vegas losing priority when you switch to another window.
    Not even sure that “losing priority” is the correct term to describe the issue. I’ve heard it referred to as “focus”.
    You posted back in July, have you found a solution? I’m looking for the same remedy and more RAM wasn’t the solution.
    Larry Brewer
  • Larry Brewer
    March 12, 2017 at 7:03 pm
    Bob, That was quick. I found a post by our friend John Renfro. Basicly a preference setting. He wrote..
    “If you don’t want this behavior you can disable it by going to Options | Preferences | General and uncheck “Close media files when not the active application” and Vegas Pro will keep a handle on the media files.”
    This is a very nice fix and speeds up the return to the Vegas program.
  • Larry Brewer
    March 12, 2017 at 7:16 pm
    That’s John Rofrano! sorry for the misspell
  • Jeremy Strong
    February 12, 2026 at 9:18 pm
    Thank you! This solved the exact same issue 9 years later on Vegas Pro 21
  • Brie Clayton
    February 12, 2026 at 9:22 pm
    Thanks for this solve, Larry!
