Activity › Forums › VEGAS Pro › Sony Vegas 12 and 11 Problem (Unmanaged Exception (0xc0000005)
  • Sony Vegas 12 and 11 Problem (Unmanaged Exception (0xc0000005)
    Posted by Sam Diamond on January 31, 2014 at 4:46 am
    So Hi everyone. I’ve been having this problem that is with my Sony Vegas it doesnt render at all it says (Unmanaged Exception (0xc0000005). Like I have been searching everywhere for my problem but no one has it so im trying to get help from here right know! to know what kind of problem it is. and im needing help its been a month and i dont know how to fix it. When ever I render this happens and i never got to render because this is my new computer.
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 11.0 (Build 700)
    Problem: Unmanaged Exception (0xc0000005)
    Fault Module: C:\Windows\assembly\NativeImages_v2.0.50727_32\PresentationCore\6c732c3d6b44d63765d84580b5057f74\PresentationCore.ni.dll
    Fault Address: 0x544137A3
    Fault Offset: 0x006937A3
    For 12
    Problem Description
    Application Version: Version 12.0 (Build 770) 64-bit
    Fault Module: C:\Windows\assembly\NativeImages_v2.0.50727_64\PresentationCore\af2ae946ac8320f0b46689dee41e1d0e\PresentationCore.ni.dll
    Fault Address: 0x29CD25C0
    Fault Offset: 0x007925C0
    Fault Process Details
    Process Path: C:\Program Files\Sony\Vegas Pro 12.0\vegas120.exe
    Process Version: Version 12.0 (Build 770) 64-bit
    Process Description: Vegas Pro
    Robert Ontiveros replied 12 years, 7 months ago 4 Members · 9 Replies
  • 9 Replies
  • Graham Bernard
    January 31, 2014 at 6:30 am
    You’ve got a Fault coming from something called “PresentationCore” from “NativeImages”? Ring any bells? Are you using any graphics that could be choking Vegas?
    Grazie
  • Stephen Crye
    January 31, 2014 at 6:32 am
    Hi Sam;
    Some questions:
    * Does it happen no matter what the source material?
    * What are the project properties?
    * what are the specs of your system and video card?
    * Does it happen when all GPU acceleration is disabled?
    * Does it happen regardless of the rendering template?
    Also, submit a support ticket to Sony Creative ASAP – they take forever to respond sometimes, so best to get that started right away.
    Steve
    Win7 Pro X64 on Dell T7500, MultiTB SATA, 8GB RAM, nVidia Quadro 2000, Vegas 12, 11, 10, 9 DVDA 6.0 & 5.2(build 135) Sony HDR-CX550V, Panasonic GH3 with LUMIX G X VARIO 12-35mm / F2.8 ASPH, LUMIX G X VARIO 35-100mm / F2.8
  • Sam Diamond
    January 31, 2014 at 8:25 pm
    I dont know about choking it. But I have a Intel(R) Core (TM) i7-4700 MQ CPU @2.40 GHZ
  • Sam Diamond
    January 31, 2014 at 8:27 pm
    They have nothing to do with the properties i can say that. The CPU when i turn it off it still does it. Yea it happens regardless but the only time when it renders is when i press ctrl + shift when it is starting up then it renders, but i have to keep doing it when ever it doesnt render
  • Stephen Crye
    February 1, 2014 at 3:12 am
    Sam, the C:\Windows\assembly\NativeImages_v2.0.50727_64\PresentationCore is part of the .net subsystem.
    For years I refered to .net as .nyet – just say no. But it has its hooks into everything. Vegas uses it.
    [wild speculation ]
    I have found that sometimes different versions of .net step on each other. Have you by any chance installed old software recently on your computer, something that might have stepped on the version of .net that Vegas likes?
    [/wild speculation]
    Is there a .net programmer in the house?
    Steve
  • Sam Diamond
    February 1, 2014 at 4:01 am
    What do you mean by .net user?
  • Sam Diamond
    February 1, 2014 at 4:04 am
    and I dont think so.
  • Graham Bernard
    February 1, 2014 at 8:37 am
    _______________________________________________________________
    [Sam Diamond] “I dont know about choking it. But I have a Intel(R) Core (TM) i7-4700 MQ CPU @2.40 GHZ”
    Are you implying that as you have got a more than adequate system, then Vegas should be able to handle all that is placed inside it? – Wrong! I’ve read of systems beefier than yours that have been choked, and it is because Vegas is such a “Good Soldier” that it will attempt and attempt and keep ON attempting to do what you ask of it. And guess what, ultimately the system suffers – and that, right there, is what you are experiencing, and until another person comes here and can provide another/better reason for why ( I’m always willing to learn!) I’ll say again – it’s the Media, not your system and not Vegas that is at the centre of this issue. Look, other NLEs would have by now have given you a bland “Can not import Media” warning, picked up their skirts and gone home! No, your system sounds good. Vegas is good. Try and attempt to make the Media comply with what Vegas CAN deal with. Sure, there could be something more fatal than what I am saying, be pragmatic: Give Vegas a chance first, if it still fails then look elsewhere for a solution. Your experience is similar, not the same, where one of our colleagues is trying/attempting to get through the BLACK colour space understanding, and THEN deliver to, whatever . . . . You’re experience is about the FRONT end and getting the media to play nice, the BLACK issue is about making BLACK Media comply with the project, is all of a much of the same issue. Know the tools and know the materials.
    Now, it’s your choice: DON’T track down the Media that is choking you getting to your creativity or DO. It’s up to you.
    If Vegas has a failing it is this: It tries too hard to ingest what you throw at it. Once I/we/you recognise this and meet Vegas halfway then this NLE will out perform your expectations. Well, not so grandiose, but you get me drift…..
    Cheers
    Grazie
  • Robert Ontiveros
    February 2, 2014 at 6:01 pm
    Hey guys I am new to all this and I recently downloaded Sony Vegas Movie Platinum and upon start up I get this error message:
    Problem Description
    Application Name: Movie Studio Platinum
    Application Version: Version 13.0 (Build 879) 64-bit
    Fault Module: C:\WINDOWS\SYSTEM32\CFHD.dll
    Fault Address: 0x00000075D94E4947
    Fault Offset: 0x0000000000004947
    Process Path: C:\Program Files\Sony\Movie Studio Platinum 13.0\MovieStudioPlatinum130.exe
    Process Version: Version 13.0 (Build 879) 64-bit
    Process Description: Movie Studio Platinum
    Process Image Date: 2014-01-13 (Mon Jan 13) 16:57:00
    Can someone help me?
    Thank you!
