Activity Forums VEGAS Pro Sony Vegas 11.0 renders unplayable/broken videos.
  • Sony Vegas 11.0 renders unplayable/broken videos.
    Posted by Jon Lasso on December 29, 2011 at 2:14 pm
    Hello.
    Whenever I render an edited video in Sony Vegas 11.0 the video gets broken in different ways depending on the media player.
    If it’s Windows Media Player Classic it doesn’t play at all. If it’s VLC it plays but it gets all choppy at the first play but is fine on the second.
    I try converting the video using AVS but only audio comes out and video is just a black screen.
    This only happens when rendering HD videos (720p, 1080p)
    Any idea?
    Al Bergstein replied 14 years, 8 months ago 3 Members · 3 Replies
  • Mike Kujbida
    December 29, 2011 at 8:11 pm
    Define “broken”.
    What are your computer specs (OS, CPU speed, RAM, # and size of hard drives)?
  • Jon Lasso
    December 29, 2011 at 11:38 pm
    i7 2600k
    8 GB RAM
    Radeon HD 5770
    I actually just found out that it only happens when it’s an HD .avi file.
    Broken as in what I just said. If I convert it with a video converter for some reason the output will be a black screen with just the audio. If I play the render on VLC media player it’s all choppy and has to load for the first play but gets fine on the second play (but after a few minutes I have to load it again as if it was the first time playing it).
  • Al Bergstein
    December 30, 2011 at 5:18 pm
    So make sure your project settings are right, and then try rendering to the “standard” Main Concept render engine. I’ve heard from others and experienced it myself sometime, that rendering to Windows Media Player is not a good option, though WMP can play the MP4 files that Vegas produces through M.C. just fine.
    You might want to make sure you have the latest Windows Media Player installed. Just like with Quicktime, different versions of the player can give different results. Which is why it’s better to just output to mp4, IMHO. At least to start with.
    You also didn’t mention if you are rendering to your C (OS) drive. Choppiness can occur as your computer tries to play a media file from the OS drive. Always render your stuff (or at least play it) from a secondary drive, so you don’t end up competing with the OS, which is doing all sorts of communication most of the time with the drive you have it loaded on (usually C). I have a 1 TB D drive that I render all videos to. I then move them to other RAID storage for safe keeping.
    Your system by and large seems adequate, so perhaps it’s just finding the right combination of physical drive locations and the right codec. Good luck.
    Al
