Activity Forums VEGAS Pro Sony Vegas 11 Aspect Problem
  • Sony Vegas 11 Aspect Problem
    Posted by Jeren Nadimi on March 27, 2012 at 12:51 pm
    I’m using sony vegas 11 64 bit, I have not render problem already before i render the videos without audio but after adding audio i start having render problems which i can not figure out.
    for example i have project and review size of 1920×1080
    but when i render the project in the same project size in any type( mov. avi. mp4.) i get the frame size changed in render.
    i didnt change anything even i tried rendering again without audio again this problem occurs in any size.
    Nick White replied 14 years, 5 months ago 2 Members · 3 Replies
  • Nick White
    March 28, 2012 at 8:45 am
    OK. I will _try_ to help here. I am not an expert, but I am struggling through just what you are, only I have got through most of the basics. I am only using Studio. I hope the settings I give are of use.
    The Project Properties are (mostly..more on that later 🙂 ) not what matter when you render. They are to do with preview and editing as much as anything.
    I will assume you are saving to disc. As far as I have seen it’s by far the best way to go about it, even if you want a DVD. I have not tried the Youtube one, but AFAICS these are just automated versions of ones you can do, and may not be the best.
    When you render, you need to set the video output size to what the chosen _renderer_ “template” does. So you need to move down the Render As window until you see Customise Template. In there you will start to go mad……but you will see choices about the Frame Height and Width. What choices you have on many of these settings depends on which template you choose. That will be enforced by what you want the output to be used for, and whether you get satisfactory output quality from that Template.
    It can be really messy working out what works for you, but in the end you will settle for one or two….however
    Now, having set the height and width, you will _still_ find that when you play the rendered output, in most cases you will see a “letterboxed” play, with it not filling the entire playback window. Here you need to go even further down the Render As DBox and ask to Stretch Video to Fill the output frame size (do not letterbox). I am not sure of the mechanics her: I would have through the player would take care of that, but anyhow….
    Having said all of that I have just found that if you set the Project Properties to an aspect ratio that does not match your input video, you get a funny AR on the output, no matter what you set in the Template.
    Hope that helps
    Nick
  • Jeren Nadimi
    March 28, 2012 at 2:50 pm
    Thank you so much for the reply it was so helpful
  • Nick White
    March 29, 2012 at 12:13 am
    I hope it does. As I say I at the stage where I am still learning, but that lets me understand how confusing this can all be.
    Nick
