Activity Forums Apple Final Cut Pro Legacy Sony V1U and Final Cut – still having problems?
  • Sony V1U and Final Cut – still having problems?
    Posted by Arturo Glass on October 27, 2007 at 5:56 pm
    I’m thinking of purchasing a V1U and have already bought Final Cut Studio 2. Just wanted to know if anyone has experience with importing 24p footage (1080i) from the Sony HVR-V1U and if there are still import issues with Final Cut Pro or if Apple has worked these issues out by now?
    Thanks.
    Craig Sawchuk replied 18 years, 10 months ago 3 Members · 3 Replies
  • Zgpinc
    October 27, 2007 at 9:38 pm
    With the KONAH LHe you solve all the problems and come in uncompressed to get the full potential fo HDV.
  • Arturo Glass
    October 27, 2007 at 11:06 pm
    If I’m ultimately shooting for DVD release, that is 1080i won’t make a difference, am I better of importing the footage in at SD ? In doing this, will I be able to import to Final Cut without any problems?
  • Craig Sawchuk
    October 28, 2007 at 8:10 pm
    The V1U is a great camera but it depends on how you will use it. It’s not so good in low-light situations, but otherwise it’s a solid choice. Regarding the 24P option, again make sure that it’s what you really want. For instance if you ever want to slo-mo its flavor of 24P, you’ll regret using the frame rate. The good news is that the camera allows you to shoot in other frame rates. I haven’t had any trouble at all importing the files into FCP…
    Craig
