Activity › Forums › Apple Final Cut Pro Legacy › Sony V1U and FCS 2
Sony V1U and FCS 2
Posted by Jason on June 26, 2007 at 8:49 pmHello All,
Does Final Cut Studio 2 support 1080 24p from the Sony V1U?
If so how?
Thank you very much.
Chris Borjis replied 19 years, 2 months ago 3 Members · 2 Replies -
Steven Gonzales
June 27, 2007 at 1:25 amI’m researching this myself, and I found this:
https://www.macworld.com/2007/06/reviews/finalcutpro6/index.php
which says: Final Cut Pro 6 also does not properly support Sony
Chris Borjis
June 27, 2007 at 4:51 amI just did a 1 hour musical shot with 3 V1U’s in the 24P mode.
worked out great, but only the 1080i60 firewire basic easy setup worked, the other (specified for sony hdv) did not.
Someone else had some 24pA only project going and they are having a helluva time getting it to work.
Unless your doing a film out there really is no reason to edit
natively at 24Pa. 24P 60i works fine.
