Activity › Forums › Audio › Sony UTX-B03 will not turn on
  • Sony UTX-B03 will not turn on
    Posted by Ron Garza on September 3, 2016 at 9:09 pm
    Wireless mic transmitter stopped powering on. Installed fresh batteries but nothing lights up. Any ideas?
    Thanks in advance,
    Ron
    Dex Coyle replied 8 years, 6 months ago 4 Members · 5 Replies
  • Ty Ford
    September 4, 2016 at 10:56 pm
    Hello Ron and welcome to the Cow Audio Forum.
    Are the batteries rechargeable?
    Some rechargeable, after a bit of use, just don’t have the voltage to fire up some devices.
    Regards,
    Ty Ford
    Cow Audio Forum Leader
    Want better production audio?: Ty Ford\’s Audio Bootcamp Field Guide
    Ty Ford Blog: Ty Ford\’s Blog
  • Richard Crowley
    September 4, 2016 at 10:58 pm
    With nothing more than that very basic symptom, it could be any number of things.
    When was it working last time? How long ago?
    Were the batteries left in? Is there any sign of battery leakage and/or corrosion?
    Recording audio without metering and monitoring is exactly like framing and focusing without looking at the viewfinder.
  • Ron Garza
    September 5, 2016 at 12:12 am
    Using Duracell Procell AA alkaline batteries. Put in a fresh set. Same results.
  • Ron Garza
    September 5, 2016 at 12:14 am
    Was working 3 or 4 days ago. No battery leakage. I opened it up and no signs of damage. My guess is either board is fried or cold solder joint. Nothing obvious.
  • Dex Coyle
    February 24, 2018 at 1:52 pm
    I know this is an old post. I’m having the same issues that you had.
    Did you find out what was wrong with the Soney UTX-b03?
    I have two sets of them. One set works and the other will not turn on. Both the transmitter and the reciever.
    I only used them 3 times over the last two years.
