Sony Stabilize Effects – “apply” not working
Posted by Anna Merry on February 16, 2014 at 3:01 pmI would like to use sfx in Sony Vegas called “Sony Stabilize”, but the button apply does not work… I can not even change the settings… What shoud I do? Please help me.
Joe Mizera replied 12 years, 6 months ago 5 Members · 11 Replies -
Steve Rhoden
February 16, 2014 at 5:18 pmDo you have the event you want to stabilize selected?
Steve Rhoden
(Cow Leader)
Film Editor & Compositor.
Filmex Creative Media.
https://www.facebook.com/FilmexCreativeMedia
1-876-461-9019 -
Norman Black
February 17, 2014 at 12:06 amHave you applied the Stabilize effect as a Media FX. You cannot apply it as a track or event fx.
When I add the effect as an event fx all options are disabled and there is a box below those controls that states the effect must be applied as a media fx. This bottom description box can be closed.
When I add as a media fx then the controls are not disabled and there is a box below the controls stating that apply must be selected.
Steve Rhoden
February 17, 2014 at 3:15 pmWhat did you do?
Steve Rhoden
(Cow Leader)
1-876-461-9019 -
Anna Merry
February 17, 2014 at 3:40 pmFirstly I was trying to add event FX and it didn’t work. If I added FX on track FX then it shown the option of stabilizer and now it works fine.
Graham Bernard
February 17, 2014 at 5:39 pm_______________________________________________________________
[Anna Merry] “If I added FX on track FX then it shown the option of stabilizer and now it works fine.”
_______________________________________________________________TIP!: I’m sure you realise that anything else you put on that track will also get the Stabilize treatment too? Maybe you want that? Better is to add the FX at the Media Level in the Project Media Pane. This ways anywhere you HAVE that footage will be stabb’d and you don’t need to waste a Track.
Grazie
Cameras: Canon XF300 + PowerShot SX50HS Bridge -
Steve Rhoden
February 17, 2014 at 7:55 pmGood tip from Graham there Anna!
Steve Rhoden
(Cow Leader)
1-876-461-9019 -
Norman Black
February 17, 2014 at 8:55 pm[Anna Merry] ” If I added FX on track FX then it shown the option of stabilizer and now it works fine.
“Interesting. If I try to add Stabilize as a track effect, I get the same message from Vegas stating the effect must be applied as a media effect. All controls are disabled.
“You’ve added the Stabilize plug-in to a track. This plug-in must be applied to a clip or subclip as a media effect.”
Graham Bernard
February 17, 2014 at 10:11 pmNorman is correct. Well, there’s a thing! I’ve never done the Stab to Track, but if I HAD here it is:-
Anna how DID you do it? Talk about getting the wrong end of the stick…. and kinda makes my “TIP” a complete waste of time!
Grazie
