Activity Forums Apple Final Cut Pro Sony SSTP files
  • Sony SSTP files
    Posted by Michael Sanders on August 26, 2017 at 10:34 pm
    Hi All.
    I’m trying to edit some SSTP RGB files from the F55. I’m 99% sure this has worked before.
    I run them through SR viewer to turn them into Quicktime .MOVs and then import to FCP X. I have the SR codec installed.
    I can see the files in the browser complete with thumbnails but when I try to play or skim the file goes black.
    Any ideas? Could it be conflicts with various codecs and plugins?
    Thanks.
    Michael
    Michael Sanders
    London Based DP/Editor
    Michael Sanders replied 9 years ago 2 Members · 4 Replies
  • Jeremy Garchow
    August 26, 2017 at 11:44 pm
    Why not use the SSTP MXF files in FCPX directly?
  • Michael Sanders
    August 27, 2017 at 7:38 am
    Hey Jeremy,
    I have tried that but it doesn’t seem to want to know – hence the question could there be an issue with my system, possibly various older codecs?
    I have installed the Sony SR codec and removed the Sony MXF import plugin which has made no difference.
    As I said I can see the files in the FCP X browser but can only see thumbnails.
    Any ideas?
    Michael
    Michael Sanders
  • Jeremy Garchow
    August 27, 2017 at 2:13 pm
    You’ve tried the usual restart and trash prefs?
    I’ve noticed that in 10.3.4, FCPX seems to take a really long time to build a cache and I’ve seen the black screen on ProRes movies too. If you can see thumbnails, that’s a decent sign that the codec is working.
    I’d try deleting the .mov versions out of there, drag and drop MXF files. I’d also trash your cache.
  • Michael Sanders
    August 27, 2017 at 7:13 pm
    So the plot thickens..
    I trashed the prefs and created a new Library, importing the files directly into it.
    Now when I press play I see the image but if I pause it, or add an effect it goes black.
    The really bizarre think is that if I create optimised media I just get a green screen.
    Will have to send a bug report to Apple I think..
    Michael Sanders
