Activity › Forums › Sony Cameras › Sony PMW Combine
  • Sony PMW Combine
    Posted by Suko Bhakti on June 17, 2013 at 4:59 pm
    I have two cameras, one is a Sony PMW EX3 and a PWM EX1R. I have plans to add another camera to combine. Is it good if I use a Sony PMW 200 or a Sony PMW EX3? How about if I use a Sony PMW 100 because I have a low budget. I use these cameras for Weddings and Church events. If anyone could help that would be great. Thank you.
    Michael Slowe replied 13 years, 3 months ago 2 Members · 1 Reply
  • Michael Slowe
    June 18, 2013 at 11:01 am
    The only thing I would say is that the PMW 200 records at 50mbps whereas the EX 1 and 3 record at 35 VBR . You probably won’t see the difference, the broadcasters seem to have settled on a 50mbps requirement, hence all the new cameras recording at that rate. Your match with either of the cameras you mention should be fine.
    Michael Slowe
