Activity › Forums › Sony Cameras › Sony PDWF 335L, HD/SDI out?
Posted by Geof Gilland on April 28, 2009 at 3:13 pmTrying to find a user or rep that has the sony pdwf 335L. Does this camera have a BNC SD/HDSI output. Brochure says yes. Sales reps say no. Thanks in advance.
Geof Gilland replied 17 years, 4 months ago 3 Members · 6 Replies -
Brian Barkley
April 28, 2009 at 4:25 pmYES, it does. See outputs below:
i.LINK: IEEE 1394, 6-pin
HD-SDI: BNC, SMPTE 292M (w/embedded audio, HD mode only)
Component Video: BNC (x1 Output) -
Geof Gilland
April 28, 2009 at 4:41 pmthanks for your response. did you pull this info from the brochure or do you have the camera. disagreement is between the sales rep and the brochure…
Brian Barkley
April 28, 2009 at 7:03 pmI got the info from B&H Photo website. I have found them reliable.
Bill Long
April 28, 2009 at 8:04 pmThe PDWF-335 does not have HD/SDI output.The PDWF-335 has component
(HD/SD Analogue) video output. The brochure states this spec.
The PDWF-355 has HD/SDI output. -
Brian Barkley
April 28, 2009 at 10:04 pmFor the 335, this is directly from the Sony website. That is all I can say.
SDI Out BNC x 1
(HD/SD switchable)
HD-SDI: SMPTE 292M (w/embedded audio)
SD-SDI: SMPTE 259M (w/embedded audio) -
Geof Gilland
April 28, 2009 at 10:14 pmmy intent in the post was to get a response from someone who owned or had a 335. i am aware of what multiple web sites say…i’ve investigated them as well.
FWIW, my salesperson has contacted Sony Sales rep and they have indicated that the brochure is not correct.(then fix it or remove it,right?) the 335 does not have HD/SDI out but the 355 does.
thanks.
