Activity › Forums › Blackmagic Design › Sony NEX and Hyperdeck Shuttle
Bill Ravens
July 15, 2011 at 2:27 amThanks for the update, Joshua.
I hope you can find a solution quickly.
Jacky Lau
July 15, 2011 at 1:59 pm -
Bill Ravens
July 28, 2011 at 6:34 pmIt seems the Hyperdeck works only with the conventional HDMI formats of 720p, 720i, and 1080i. It does not work with 1080p on the FS100. I beleive this is happening because, unlike earlier models, the FS100 outputs in a native 1080p60 format, that is recorded internally, in all 1080p modes as 1080psf(progressive segmented) . Decoding of true 1080p60 is not routinely handled by any of the current recorders. The only application I’ve found that can even recognize the native 1080P60 format is Adobe CS5.5.
I just hope that 3rd party vendors, like Convergent Design, BMD, Sound Devices and ATOMOS can get it together enough to offer firmware updates to 1080P60 in the near future, however, I expect that the processors in these 3rd party recorders can’t handle the data rate of 1080p60.
Shawn Sutherland
September 9, 2011 at 10:03 amAs a proud owner of the NEX-FS100UK Camera with the Hyperdeck Shuttle I can’t begin to tell you how pleased I was to hear that there’s a simple Workflow for removing the 2:3 Pull Down using Apple Compressor available with Final Cut Pro Studio:
https://blog.abelcine.com/2011/08/19/simple-workflow-for-removing-23-pull-down/
Couldn’t be happier.
There’s just one little problem.
I don’t own a Mac.
I own a PC with Adobe Premiere Pro CS5.5
OK now what?
Any ideas?
