Activity Forums DaVinci Resolve Sony LMD-2110W 21.5″ Professional LCD Monitor – How good or bad is it?
  • Sony LMD-2110W 21.5″ Professional LCD Monitor – How good or bad is it?
    Posted by Caio Simbula on January 12, 2015 at 4:34 am
    Hi All,
    I’m looking for an entry-level HD broadcast monitor for color grading on my home system. I’m running a MacPro 8-core with 32GB RAM and a BlackMagic Intensity Card.
    Currently I downconvert the HD signal to SD and monitor on a Sony PVM-20m2u. I check the calibration everytime I use it with color bars in blue-only mode. It pretty much works out decent for color grading, but something I don’t notice at SD resolution is when the picture breaks up if I grade it too far, especially with DSLR footage or any compressed codec.
    So my question is, has anyone used the Sony LMD-2110W 21.5″ LCD monitor? What was your experience with it? I know it’s a sub-$1000 monitor, someday I will get an FSI or some decent JVC/Panasonic/Sony broadcast monitor. My question is will the cheapie (yet actual broadcast monitor) be worthwhile to upgrade to from my SD monitor? Or is the LMD-2110W so bad, that I should just stick with my current SD solution and save up for a better monitor?
    I also don’t want to deal with using computer monitors and any weird workarounds, I want a normal broadcast monitor that has blue-only functions and uses actual Rec.709 space, none of this HP/Eizo/whatever solutions. Thanks for any suggestions.
    caioFILM
    caiofilm@mac.com
    https://web.mac.com/caiofilm
    Joseph Owens replied 11 years, 8 months ago 2 Members · 1 Reply
  • Joseph Owens
    January 13, 2015 at 8:21 pm
    [Caio Simbula] “I also don’t want to deal with using computer monitors and any weird workarounds, I want a normal broadcast monitor that has blue-only functions”
    That is a good, pragmatic approach. The issue I have with setting up a display with blue-only is that it only gives a “corners of the envelope” setup, and doesn’t really help with the overall color accuracy of a monitor’s total gamut fidelity. “Blue-only” was developed to set hue and saturation for baseband composite video, when there was a real “phase” component that was relevant. In digital component, it is practically meaningless.
    The investment in a probe and calibration software would put you well in the ballpark and still a bit less expensive than a full-up reference monitor — and you would also find out what the deficiencies are with your own solution, for good or ill.
    jPo
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
