Activity Forums Adobe Premiere Pro sony hvr-Z1 camera problems with pro 1.5
  • sony hvr-Z1 camera problems with pro 1.5
    Posted by Jody Kerr on August 14, 2005 at 9:32 am
    Hi all,
    We have this camera at work now, all is great, BUT…. problems start when we connect via firewire to the PC.
    We get the error message cant activate recorder, try resetting camera???
    We have triple checked all our capture / project settings but atill have problem.
    This is very frustrating, we have urgent work to do, but can tget footage from camera into premiere pro.
    PC is 3.4gig P4 2 gig ram, ati radeon 9550, matrox rt100 extreme. By the way we have tried taking matrox card out of picture, but get same error regardless.
    HELP!!!!!!
    Cheers in advance people!!!
    Supervideo replied 21 years ago 5 Members · 5 Replies
  • Mike Velte
    August 14, 2005 at 11:24 am
    Suggest a process of elimination;
    Will your cam connect OK on another PC?
    Does another DV cam connect OK on your PC?
    Does Device Manager SEE your cam in Imaging Devices?
    Try another firewire cable?
  • Jody Kerr
    August 14, 2005 at 11:32 am
    Hi Mike,
    thanks for the reply.
    Will your cam connect OK on another PC? no
    Does another DV cam connect OK on your PC? yes
    Does Device Manager SEE your cam in Imaging Devices? no
    Try another firewire cable? tried many others, same result.
    Mike I have been reading on the adobe forums that ALOT of other people are having same problems with their Z1.
    Best answer I have seen is to try using aspect HD, but surely I shouldnt have to buy another expensive software package to let me capture HDV, or even DV from our very expensive Z1!
    They are also saying that the HDV timecode appears to have problems as well?
    Apreciate you thoughts and help on this!
  • Tim Kolb
    August 14, 2005 at 1:24 pm
    You have upgraded to PPro 1.5.1, correct?
    Tthis is the version that will handle HDV without the Aspect plugin (though you still may want it for speed.)
    I’ve used the camera with PPro 1.5.1 and Aspect and haven’t had any issues. (not that that is helpful for you…just letting you know it’s possible).
    TimK,
    Kolb Syverson Communications,
    Creative Cow Host,
    2004-2005 NAB Post Production Conference
    Premiere Pro Technical Chair,
    Author, “The Easy Guide to Premiere Pro” http://www.focalpress.com
    “Premiere Pro Fast Track DVD Series” http://www.classondemand.net
  • Steven L. gotz
    August 14, 2005 at 5:40 pm
    And the Matrox can not capture HDV to my knowledge anyway.
    You must have WinXP SP2 installed or you won’t have the drivers you need.
    Steven
    Adobe Premiere Pro 1.5.1 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Supervideo
    September 1, 2005 at 11:47 am
    Just my 2 cents I had a alike problem but I could capture on other computers and with other cameras .. So I say try a different 1394 card .you would think thier all the same
    but thats what solved the problem for me . I tried a belkin 1394 card and it worked fine .
    The one that gave me trouble was a chepo from a compter show about 15 bucks …
    Hope this helps
    Steve
