Activity Forums Apple Final Cut Pro Legacy Sony HDW-1800 Timecode breaks during capture
  • Sony HDW-1800 Timecode breaks during capture
    Posted by Joel K. on December 16, 2008 at 7:15 pm
    The tape is fine. There are no timecode breaks on the tape. However, when I am capturing with Final Cut, every 4-7 seconds, capturing is interrupted and I get the error message “Located TimeCode Break” and the capturing process is stopped. Is this a deck issue? A computer issue? A final cut settings issues? Thank you in advance.
    Michael Gissing replied 17 years, 9 months ago 2 Members · 2 Replies
  • Joel K.
    December 16, 2008 at 7:18 pm
    I am using a blackmagic card and the capture settings are Blackmagic HDTV 1080i 59.94
  • Michael Gissing
    December 16, 2008 at 9:20 pm
    Both the HDW1800 and the Decklink card need to have a common reference. If you have a black burst generator, feed it to both devices ref in. The HDW must be set to reference to external, not SDI.
    If you have no reference then use the Decklink ref out to the HDW1800.
