Activity › Forums › Apple Final Cut Pro Legacy › Sony HDV on Panasonic tape to FCP Apple Pro Res
Posted by Julia Morris on May 9, 2011 at 6:33 amI have HDV footage shot on a Sony HVR-V1P camera, recorded on Panasonic MDV tapes. Trying to capture in to FCP7 with Apple ProRes (tested in HDV also)and neither will capture footage with new clip for each start/stop point. I end up with one long clip. I have tried the same settings and capture will work for footage shot on Sony tapes with same recording process etc.
Has anyone encountered this problem? Any ways around it? Any thing I am doing wrong?
Jerry Hofmann replied 15 years, 4 months ago 2 Members · 5 Replies -
Jerry Hofmann
May 9, 2011 at 3:32 pmNot sure what’s happening, but be sure the start/stop detection is turned on in the log and capture window in the Clip Settings tab. If it is and it still fails, try trashing your FCP preference files. If it still fails, then I’d just not use that tape any more..?
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Julia Morris
May 10, 2011 at 12:34 pmThanks Jerry. After I posted the next three tapes worked with separate files for start stop and then the last two reverted to one big clip capture. Apparently no change in recording settings for each tape and definitely no change in capture settings. I then tried trashing the preferences. No change. Very strange.
Jerry Hofmann
May 10, 2011 at 3:20 pmThe start/stop feature relies on the time of day code laid down by HDV and DV. It jumps forward in time each time you pause then start again. If this signal isn’t found (likely because of the tape stock or the way the camera is tracking the tape I’ll wager) then it can’t perform the function.
It’s not your settings, it’s related to the above in some way I’ll bet.
Jerry
Current DVD:
Julia Morris
May 11, 2011 at 1:12 amI just talked the camera operator for this project and I think you have pointed us in the right direction! She didn’t have the camera date and time set until the the forth tape – the one that started working.
Thanks for your time. -
Jerry Hofmann
May 11, 2011 at 12:01 pmYou’d think the camera lays it down no matter what… but apparently not.
I’d just capture the whole tapes then, and subclip the long captures.
Jerry
Current DVD:
