Activity › Forums › Apple Final Cut Pro Legacy › Sony HDV camcorder won’t show HDV on external monitor from FCP HD?
  • Sony HDV camcorder won’t show HDV on external monitor from FCP HD?
    Posted by Nigel on October 5, 2005 at 10:13 pm
    My new HVR-A1E Pal can’t transfer HD video from Final Cut HD to my external monitor via iLINK . The HD video is also don’t shown in the camera display.
    No problems when I work in DV format and all other functions works good.
    Any ideas please?
    Adolfo Rozenfeld replied 20 years, 11 months ago 8 Members · 12 Replies
  • 12 Replies
  • Shane Ross
    October 6, 2005 at 12:27 am
    FCP HD doesn’t work with HDV in it’s native format. You need FCP 5 for that. But even then you cannot view the image on an external monitor via Firewire. The only HD format that FCP can do that with is DVCPRO HD.
    #25 HDV external Monitor Viewing
    Shane’s Stock Answer #25 – HDV external Monitor Viewing
    To view HDV on an external monitor you are going to need to purchase a capture card, like the ones Decklink or AJA offer. They will both play out HDV in real time. The catch is that you cannot view this on a regular TV or NTSC monitor. Since this is HD, an HD monitor will be needed.
    HDV cannot be played out of FCP via Firewire because it’s Long GOP structure is too taxing on your processors to spare the system resources needed to drive an external monitor.
    For this, and other exciting stock answers visit http://www.proapptips.com
  • Walter Biscardi
    October 6, 2005 at 12:56 am
    [Shane Ross] “HDV cannot be played out of FCP via Firewire because it’s Long GOP structure is too taxing on your processors to spare the system resources needed to drive an external monitor.”
    Yet another reason why HDV is a format I avoid as long as humanly possible. DVCPro HD is just so easy.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
    Now editing “Good Eats” in HD for the Food Network
    G5 Dual 2.0, AJA Kona 2, Medea FCR2X
  • Shane Ross
    October 6, 2005 at 1:02 am
    I have yet to be presented with HDV footage, but if I got any, I would offline it DV then online it 8 or 10-bit uncompressed.
  • Walter Biscardi
    October 6, 2005 at 1:10 am
    [Shane Ross] “I would offline it DV then online it 8 or 10-bit uncompressed.”
    I would just capture it straight up as 8bit uncompressed here I suppose, depending on how much material there was. It would certainly make it much easier to work with than native HDV.
  • Steve Connor
    October 6, 2005 at 7:18 am
    [Walter Biscardi] “I would just capture it straight up as 8bit uncompressed here I suppose, depending on how much material there was. It would certainly make it much easier to work with than native HDV.”
    Just capture Native HDV, if you have a fast system, working in HDV is only marginally slower than DV, then when you are finished render out your finished timeline to uncompressed HD for Titles/FX the quality is superb and the workflow is very easy.
    The mistake a lot of people are making is assuming that HDV is a “cheap” option, hence the ENDLESS posts on here about not being able to monitor it through the camera!
    If you use the format in a professional setup, it has a lot of advantages. It is great for “B” roll shooting alongside higher end HD, it’s got us out of trouble a couple of times where the main camera has missed the action or been a little soft (happens in HD!)
    Those who are turning their noses up at HDV are missing out on a valuable (and Cheap) extra tool to work with.
    Steve Connor
    Cardinal HD
  • Adolfo Rozenfeld
    October 6, 2005 at 8:28 am
    “The catch is that you cannot view this on a regular TV or NTSC monitor. Since this is HD, an HD monitor will be needed”.
    This is not true for the Decklink cards, at least. You don’t even need an HD capable card. All Decklink cards can perform a software RT downconversion to their component/SDI outputs and AFAIK this works too with HDV.
    Adolfo Rozenfeld
    Buenos Aires – Argentina
    https://www.adolforozenfeld.com
    adolfo@adolforozenfeld.com
  • Shane Ross
    October 6, 2005 at 8:34 am
    Good to know
  • Folval
    October 6, 2005 at 9:51 am
    Thank you,
    but is not possiblle that a software as FCP 5 Studio (more than 1000
  • Mark Maness
    October 6, 2005 at 4:21 pm
    Well, I may be possible whenever the terabyte processor is available. It way too taxing on the processor of the computer to output HDV thru firewire. And I’m pretty sure that you will this is the case with all of the editing packages that have HDV support.
    _______________________________
    Wayne Carey
    Schazam Productions
  • Michael Horton
    October 6, 2005 at 4:30 pm
    Have you tried this Adolfo? Would be very cool if it worked.
    Michael Horton
    lafcpug
    https://www.lafcpug.org
