Activity › Forums › VEGAS Pro › Sony HDR XR550V
  • Sony HDR XR550V
    Posted by Doug Ellis on May 12, 2010 at 7:21 am
    I’m considering buying the Sony HDR XR550v camcorder. Will it work well with Vegas Movie Studio Platinum 9.0? Thanks for your advice.
    Dale Mcclelland replied 16 years, 4 months ago 2 Members · 2 Replies
  • Dale Mcclelland
    May 14, 2010 at 3:28 am
    I am using the XR500V with Movie Studio platinum 9.0b with no problems (my OS is Win 7 64 bit). As you probably know, the XR500V is the same as the XR550V except it has a smaller hard drive.
    You might want to go to the Sony Creative Software Movie Studio forum and look around. There is a work-around you need to do to avoid crashes when rendering AVCHD in Movie Studio. Search on “CFFExplorer” if you are using a 64 bit OS. If you are using a 32 bit OS, also search on BCDEdit (32 bit OS’s need two work-arounds).
  • Dale Mcclelland
    May 18, 2010 at 3:19 am
    I just noticed that you said you have the XR550V. I was thinking of the XR520V when I said it was the same as my XR500V except for the hard disk size. I see now that the XR550V is a newer model than the 500/520, so my comments may not apply. Sorry.
