Activity Forums Apple Final Cut Pro Legacy Sony HDR-FX1 Help
  • Sony HDR-FX1 Help
    Posted by Fo_group on August 16, 2006 at 4:25 pm
    I recently got a FX1 and having some issues logging and loading clips into FCP. If you have an FX1 and use FCP, I would appreciate knowing what AV settings you’re using. I can log clips, but it appears that FCP is not seeing the timecode on the camera when I’m actually digitize the video. Any advice?
    Rendertainmentllc replied 20 years, 1 month ago 3 Members · 3 Replies
  • Matthew Brunn
    August 16, 2006 at 4:49 pm
    I use the easy setup for HDV. Works like a charm. What is your FCP version? What hardware are you trying to run it on?
    Hope this helps-
    Matthew
    Quad 2.5 G5
    OSX 10.4.X
    Ram 4GB
    FCP 5.1/AE 6.5/DVDSP4
  • Fo_group
    August 16, 2006 at 5:13 pm
    I have the latest version of FCP. I’m running it on an Intel IMac, 1G mem., 256M video card.
  • Rendertainmentllc
    August 16, 2006 at 10:45 pm
    I agree. I’ve never had any problem when I’ve used the Easy Setup for HDV 1080 60i. Everything works like a charm.
