Activity Forums Avid Media Composer Sony HDCam Mojo-friendly?
  • Sony HDCam Mojo-friendly?
    Posted by Tom John on April 21, 2005 at 5:50 am
    Hi, all,
    Just got in from NAB. Wondering if the Sony HVR-Z1 HD Camcorder would be compatible with Avid Express Pro via the Mojo. (Seeking to capture in SD for now.) Sony refers to their firewire out signal as “DV-Cam” while Avid cites Mojo compatibility with “DV sources.” – The same? (I’ve used my little ol’ Mini-DV camcorder into Mojo with no problems.) Also the same 4-pin firewire IE-1394 on both units.
    Best,
    Tom
    DesertVideo@earthlink.net
    Ronn replied 21 years, 4 months ago 3 Members · 3 Replies
  • Chris Waddington
    April 21, 2005 at 7:53 am
    Hi Tom,
    I have used the FX1 (consumer version) with Mojo and Xpress Pro 4.6 without any problems. Just set the camcorder to down convert out of the FireWire and you should be good to go. It even controls the camcorder although I haven
  • Tom John
    April 21, 2005 at 4:13 pm
    Many thanks, Chris! I wanted to confirm that before I told my bosses to sink $10K into two of ’em!
    – TW
  • Ronn
    April 25, 2005 at 2:44 pm
    Chris – are you running the FX1 into the 4pin DV on the mojo – or going through another 1394 card, separate from the mojo? Just asking because the latter is the only way I’ve gotten DV to work with my mojo (that is, with a DV deck, I have an FX1 but haven’t tried it w/mojo yet).
    Ronn
    ronn at kilby dot com
