Activity Forums Sony Cameras SONY HDCAM EX1-workflow with FCP
  • SONY HDCAM EX1-workflow with FCP
    Posted by Vinod Raja on April 20, 2008 at 6:39 am
    I am using a Mac G5 with a Motorola processor,the one before Intel came to be used in Mac systems. Wish to know from the group if the compression codec of Sony HDCAM EX is compatible with my edit system. On reading about the camera i found that the trans coding software that is given with the camera operates only with INTEL based Macs. Will be a great help if some one here could clarify this. Thanks.
    Rick Diamond replied 18 years, 5 months ago 5 Members · 5 Replies
  • Craig Seeman
    April 20, 2008 at 1:16 pm
    Sony XDCAM Transfer 2.5.1 (rewraps to MOV) works fine with G5.
    Only Clip Browser doesn’t work on G5 and isn’t necessary.
  • Vinod Raja
    April 20, 2008 at 6:33 pm
    Thanks so much for the info Mr.Craig Seeman.This means that i can go ahead and film my next project on Sony XDCAM EX.
  • Don Greening
    April 20, 2008 at 6:54 pm
    [Vinod Raja] “Thanks so much for the info Mr.Craig Seeman.”
    Wow. Now that’s what I call respect.
    – Don
  • Noah Kadner
    April 21, 2008 at 5:49 pm
    That said, ProRes HQ is something you’ll potentially want to use in your EX1 workflow and that does require Intel. It’s a really good idea all around to look into the upgrade- everything goes a lot faster especially your renders, etc.
    Noah
    My FCP Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color. Now featuring the Sony EX1 Guidebook
    https://www.callboxlive.com
  • Rick Diamond
    April 22, 2008 at 1:31 am
    I’m planning on getting the EX1 and upgrading my power pc G5 to accomodate HD. All the specs on the Apple site show that this should be possible. No mention of Pro-res HQ not being able to run on this box. Is it just too slow or incompatible.
    thanks,
    Rick
