Activity Forums Apple Final Cut Pro Legacy Sony HCR-HC1 NTSC/PAL question
  • Sony HCR-HC1 NTSC/PAL question
    Posted by Dene Wilby on January 20, 2006 at 9:12 pm
    Hi all
    Hopefully someone can help me with this.
    We are based in the UK and have some footage which was filmed by a crew in the USA using Sony FX1 HD cams (NTSC). We want to get a Sony HC1 and get this footage into our Mac using FCP5. Will the UK sourced HC1 output a correct signal to allow us to do this and produce NTSC material for DVD? The reason I ask is because you cannot do this with SD footage due to the PAL players only sending out a pseudo NTSC signal, right?
    Hope that makes sense.
    Dene
    Dene Wilby replied 20 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
