Activity Forums Apple Final Cut Pro Sony FX30 media to ProRes
  • Sony FX30 media to ProRes
    Posted by David Mayer on April 12, 2024 at 5:55 pm
    I use EditReady to convert the 4k .mp4 files from the card in my Sony FX30 to
    ProRes but the converted files are gigantic and they seem to mess with Final Cut. Do you
    know of a better way to convert?
    Doug Metz replied 2 years, 4 months ago 3 Members · 10 Replies
  • 10 Replies
  • Jeremy Garchow
    April 12, 2024 at 6:18 pm
    There are six flavors of ProRes:
    Proxy
    LT
    SQ
    HQ
    444
    444XQ
    The data rate for everything but Proxy is going to be higher than fx30 mp4 files, so bigger files should be expected. Final Cut does just fine with any flavor of ProRes, but depending on your system, you may need to boost either your drive speed, processing speed, or both.
    Please give us more information about your setup.
  • David Mayer
    April 12, 2024 at 6:49 pm
    Thanks, Jeremy.
    I just updated my creative cow tech info.
    My projects usually combine media from my FS5 and FX30.
    Wondering if that is one issue.
    Also should i upgrade my edit drive?
    2 TB Samsung Portable SSD T7 Touch
    (1,000 MB/s)
  • David Mayer
    April 12, 2024 at 6:50 pm
    is editing with the much smaller .mp4 files off the FX30 card an option?
  • Jeremy Garchow
    April 12, 2024 at 7:08 pm
    Your drive is great, love those little powerhouses, it’s your MacMini that is probably struggling with the 4k ProRes. Yes, you can use the mp4s.
  • David Mayer
    April 12, 2024 at 7:15 pm
    OK. Using the .mp4 files might help a lot. Any downside to that?
  • Jeremy Garchow
    April 12, 2024 at 7:19 pm
    Not really. You can always transcode to ProRes at any time in Final Cut by right clicking the media and choosing Transcode Media > Create Optimize Media.
    Edit Ready may insert timecode in to the ProRes files, and FCPX usually imports mp4 files with 00: tc, so that would be the only downside, in that you might not be able to link the orig mp4 to the EditReady made files, but you’d have to test that.
  • David Mayer
    April 12, 2024 at 7:22 pm
    great info, thanks again Jeremy
    will transcode to prores in final cut result in bigger files?
    will final cut be happier with prores?
  • Jeremy Garchow
    April 12, 2024 at 7:36 pm
    Yes, ProRes will be bigger, just like the EditReady made ProRes files.
    FCP can handle either the mp4, or ProRes, but the Mac mini will have a more difficult time with the ProRes files since they are larger and have more data to process.
  • David Mayer
    April 12, 2024 at 7:45 pm
    Makes sense.
    Will try .mp4 next time.
    Just checked file sizes.
    The job was about 90-minutes.
    FS5 ProRes direct from the Ninja – 381 GB
    FX30 mp4 – 74 GB
    EditReady converted .mp4 to ProRes – 766 GB
    Is there a more powerful Mac mini now or would I need a
    different computer?
  • Doug Metz
    April 16, 2024 at 8:11 pm
    One other thing to consider is the cable connecting your drive to the Mini.
    I had a 2020 M1 for a few years and didn’t have any issue with 4K ProRes files, but I was working off an 8-disk RAID with a certified TB3 cable. You should test your cable to be sure you’re getting every bit of bandwidth that T7 will handle.
    Same connector ≠ same functionality.
