Activity › Forums › Sony Cameras › Sony FS7
Sony FS7
Posted by Olivier Prudhomme on February 24, 2019 at 4:46 pmIs this actually a good place for topics on this specific camera?
Los Angeles – TV Promo Editor – FCP – AVID
Andy Ford replied 6 years, 8 months ago 4 Members · 4 Replies -
David Tomasiello
July 9, 2019 at 10:51 amIs it possible to record the high frame rates that the Fs7 is capable of ,for example 120fps onto an external recorder like the Atomos Shogun 7? Is this possible by using the existing sdi out. And what about in the case of recording 4K 60fps which i believe is the maximum frame rate the Fs7 does in 4K. Is it a case of connecting an Atamos 4K recorder via the sdi output or do I need the Fs7 RAW adapter dock. Thanks in advance.
Andy Ford
January 14, 2020 at 6:25 pmThe Sony XDCA-FS7 Extension Unit is required to output 12-bit 4K RAW footage to external recorders. This would be up to 59.94p and up to 60fps. It’s been a while since I’ve done this, but I believe in 2K RAW you can get up to 240fps.
In addition, you would need it to do built-in ProRes 422 1080p recording and for Genlock/Timecode connectors if you are doing multi-camera shoots.
A Shogun Inferno can record up to 10-bit 422 ProRes/DNxHR. Up to 4K at 60fps and 2K at 240fps.
