Activity Forums Sony Cameras Sony FS5 GPS to set Time Code, Multi-Cam
  • Sony FS5 GPS to set Time Code, Multi-Cam
    Posted by Michael Harrington on June 20, 2018 at 2:31 pm
    Has anyone used the GPS feature on the Sony FS5 to set TC, perhaps to multi cameras?
    Renting a couple Sony FS5 for a multi-cam 8 day road trip and of course would like to match timecode and since FS5 will not allow TC Jam Sync so I’ll have to manually set TC. Been there done that many times.
    I found this in a Sony press release and curious if anyone has tested this.
    Also the GPS will now work (provided you have the handle attached), so footage can be geotagged for future reference and the cameras internal clock can be synchronised to the GPS time signal. This may be useful for multi-camera shoots as at least the time on each camera will be exactly the same.
    Thank you
    Michael Harrington
    MacBook Pro (Retina, 15-inch, Mid 2015)
    2.5 GHz Intel Core i7
    16 GB 1600 MHz DDR3
    AMD Radeon R9 M370X 2048 MB
    Apple Cine Display 30\”
    Thunderbolt 2 Dock
    GTech GSafe, GTech Drives
    Adobe CC2017
    Michael Harrington replied 8 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
