Activity › Forums › Sony Cameras › Sony FS 700 slow motion and external recorder
  • Sony FS 700 slow motion and external recorder
    Posted by Rainer Bergomaz on February 8, 2013 at 7:24 am
    For Wildlife shots in France I need some slow motion shots. As the budget is limited I want to use the Sony FS 700.
    As I understood when shooting 240fps the HD SDI output of the ring buffer will be 1080p/50. To get a higher quality I want to use the Gemini Recorder.
    But what is the FS700 HDSDI Output when shooting 720p with higher frame rates? Is the HDSDI output 720p? If – I cannot find any recorder able to record these shots.
    Any ideas or suggestions?
    Charles
    Eric Sternberger replied 13 years, 5 months ago 2 Members · 3 Replies
  • Eric Sternberger
    February 9, 2013 at 8:39 am
    You have to set the sdi-output to 1080i on the camera. then you can record it with a recorder even without 3G SDI, like the samurai.
    I testet it myself with the samurai, it has to be set to HD-SDI / TC-Run and then it detects the output of the buffer and records it automatically.
    But: This way you are recording interlaced Material!
    For progressive you need a 3G-SDI capable recorder, like the gemini or the sounddevice PIX
  • Rainer Bergomaz
    February 12, 2013 at 1:09 pm
    Hi Eric,
    thank you for answering. But as you suggested I have to record in progressive mode. And this is the problem (I guess).
    Gemini is able to record the 240 frames per second 1080p/50 output over 3G. But which kind of signal is coming out of the 3G port if the camera is set to 720p/480 slow motion mode? I guess the output will be 720p/50 or? And as far as I know no external recorder is able up to know to records this? Or am I wrong?
    Charles
  • Eric Sternberger
    April 3, 2013 at 10:18 am
    Hi Charles,
    why do you want to record 720p in the first place? The camera can record 1080/60p and the gemini can record that.
    Regards!
