Activity Forums Sony Cameras Sony FS 5 ii and canon glass
  • Sony FS 5 ii and canon glass
    Posted by Mike Santaella on November 16, 2018 at 1:17 am
    I recently purchased a Sony FS 5 ii without the addition of the Sony kit lens, hoping that my canon glass will be a good choice when using a metabones adapter. I have a metabones EF to e mount adapter already that I use with a Sony A7Sii. I’m considering using my canon 24-105 f4 as an all around lens to use since it has stabilization and a good all around range. Should I look into buying a separate metabones speed booster in order to gain another stop as well as keep the native focal length(s)? Does anyone have any experience using canon L line lens’ with this or similar Sony cameras? (I also use canon 50mm1.2L, Canon 24 1.4L, Canon 70-200 2.8L ii, Canon EF-s 10-22mm))
    John Treffer replied 7 years, 8 months ago 3 Members · 3 Replies
  • Blaise Douros
    November 16, 2018 at 9:27 pm
    I use the Canon 24-105 on the FS7 with a speedbooster. I rarely use other lenses, aside from a 100mm macro lens. There are sharper lenses out there, but for what I do, it’s a perfect all-around lens that’s good for almost every shooting situation.
  • Mike Santaella
    November 16, 2018 at 9:35 pm
    Thanks for your reply Blaise Douros, I appreciate your insight / experience with this setup. I bet gaining an extra stop is nice too (using metabones speed booster). Looking forward to finally upgrading!
  • John Treffer
    December 20, 2018 at 8:13 pm
    I’m using an FS7 with a kit lens and a couple of canon and canon-mount lenses. I have both, the metabones adapter and the speedbooster.
    One year back I tested some Sigma ART lenses with both metabones and I discovered that the speedbooster does affect the image quality. Sharpness and deformation significantly increases, especially towards the corners.
    However I still sometimes use the speedbooster for an extra wide angle or for extra light. But I use the adapter 9 out of 10 times.
