Activity › Forums › Avid Media Composer › Sony FS 100?
Sony FS 100?
Posted by Dustin Schmitt on March 10, 2012 at 12:22 amHello,
Was wondering the best work flow with the ingestion Sony FS 100 file format with Avid? Do I import? AMA? Trying to avoid timely trial and error.
Dustin Schmitt replied 14 years, 6 months ago 2 Members · 6 Replies -
Tina Hedegaard
March 10, 2012 at 8:37 amHi Dustin
I’ve been doing some testing with footage from this camera.
The way you should ingest depends on which version af Avid you have.It records in AVCHD.
Avid 6 can AMA-link AVCHD, so that’s the way to do it, and then transcode it.
Avid 5 – 5.5.3 can’t AMA-link ACHDK, you can import the .mts, but I’ve got bad experience with it. I would recommend you to use clip wrapper – it rewraps the AVCHD-codec to H.264.mov, and then AMA-link (then you can transcode clips from several cards at one time – or you can import the .mov files.Hope it helps
Yours Sincerely
Tina Hedegaard
Editor | Final Cut Pro 7 | Media Composer 5.0 -5.5
Mac OS 10.6.7 -
Dustin Schmitt
March 10, 2012 at 6:57 pmThanks Tina,
The Clip Wrap totally worked. Do you know if Avid works with Apple Pro Res 422? I can’t seem to import or link to it. If not I’ve got FCP but I’d rather be using Avid at this point.
Tina Hedegaard
March 10, 2012 at 7:03 pmWhich version of Avid do you have.
I’ve only tried AMA-linking apple prores quicktimes in version 5.0.4 and newer – and then transcoding it afterwards.
I’ve experienced that AVID can’t AMA-link to a folder with “the do not use”-signs, i.e. / : .
Yours Sincerely
Tina Hedegaard
Mac OS 10.6.7 -
Tina Hedegaard
March 10, 2012 at 9:13 pmHi Dustin
Avid 5.5 is born with AMA to quick times, so it’s not the plugin that’s missing.
Let’s see if we can narrow it down.– Your files are apple prores 422 (.mov)
– You haven’t got any “/ : ” etc in your file path or filename?
– is it only the prores files you can’t ama-link and have you tried some different files – both different prores files and files of other formats.
– can you import the prores files?Yours Sincerely
Tina Hedegaard
Mac OS 10.6.7 -
Dustin Schmitt
March 18, 2012 at 11:34 pmHi Tina,
I used clip wrap to convert all of the Sony footage to the DnXHD codec. Once I do this, the file comes out as a .mov file? Is this correct? Once it’s done do I do an import or a Link to AMA?
Thanks a million.
