Activity Forums VEGAS Pro Sony File Interface Surrogate ERROR message
  • Sony File Interface Surrogate ERROR message
    Posted by Jason Yip on October 25, 2009 at 7:19 pm
    Got this error message today “Sony File Interface Surrogate (not visible) has stopped working – A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.” I am running Vegas 9 Pro and this occurred when dropping an mp4 on the timeline.
    John Rofrano replied 16 years, 11 months ago 2 Members · 3 Replies
  • John Rofrano
    October 25, 2009 at 8:18 pm
    Where did the file come from? What codec does the mp4 use? It sounds like Vegas doesn’t support it or recognized it but wasn’t prepared for what was in the file.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Jason Yip
    October 26, 2009 at 5:24 am
    This was a video vile from a Flip Mino HD.
  • John Rofrano
    October 27, 2009 at 1:57 am
    OK, I just downloaded some test footage from the Flip Mino HD and dropped it into Vegas Pro 9.0b and it played fine. Are you using the 9.0b version of Vegas Pro (which is currently the latest). If not, you should update to the 9.0b version.
    I did notice that playback was choppy until I set the project to match the media (specifically 30.00fps instead of 29.97). After that Vegas Pro 9.0b smoothly played back the Flip Mino HD mp4 file at full frame rates with pretty impressive quality.
    Here is how you match the project to the media using the Project Properties (Alt+Enter) window:
    If updating to 9.0b and matching the project to the media doesn’t fix your problem, then you may need to convert the files to a format that is easier for Vegas to edit. I used Avidemux 2.5 to convert the file to MJPEG video with PCM audio and it played back smoothly in Vegas as well. You could also use the HuffYUV or Lagarith codec for even higher quality (and larger file size).
    ~jr
