Activity › Forums › Adobe Premiere Pro › Sony F5 XAVC footage in Premiere CS6
Posted by Don Mcvey on March 8, 2013 at 3:44 pmWondering if anyone can help. PLEASE HELP!!!
Trying to get 1080p XAVC footage from an F5 to work in Pr CS6 (Mac). It imports, but when I try to do anything with it, it crashes. Apparently I need a plug in. Looked at Rovi Totalcode but it’s $350 and only for a PC.
Does anyone know what I can possibly do???
Also, anyone got it to work with FCPX? Last resort, I’ll download the demo and edit in that 🙁
Darren Edwards replied 10 years, 10 months ago 19 Members · 28 Replies -
Tero Ahlfors
March 8, 2013 at 7:48 pmI don’t know if there’s support for that codec yet in Adobe apps. It does work in Sony Vegas (well according to them). It’s Windows only though.
Chris Paul
March 8, 2013 at 9:53 pmWent to a Sony demo- the rep said that Premiere 6.5 will support it. In the meantime the free version of Blackmagic DaVinci resolve will convert it.
Chris Paul
POV -
Scott Foreman
March 9, 2013 at 1:15 pmA few notes on the XAVC workflow, because I am stuck as well.
:: DaVinci lite only exports 23.97 or 24, so if you record video at 30 or 60, your output will be out of sync.
:: Sony’s content browser does not export, anyone with knowledge to the contrary, please please do enlighten us all.
:: Premiere Pro 6.5 does not support this codec.
Anyone who has successfully shot with the Sony F5 or F55 and transcoded the native XAVC files to ProRes 422, PLEASE tell us how you did it.
John Gurney
March 9, 2013 at 3:59 pmImpossible to do at this point on a mac as far as I know. We received our F55 last week and did a test with XAVC. Crashes PP6.02 and Media Encoder. Sony told us that we had to wait till PP7 comes out to use it. We had a commercial to shoot this week so we had to put the camera in XDCAM mode in order to use the files. The only benefit of this was the ability to shoot S-GAMUT. Even at XDCAM level, the footage looks wonderful! Can’t wait till we can use XAVC.
Don Mcvey
March 10, 2013 at 8:27 amThanks John. I actually went ahead and shot the XAVC. Realised I could use DaVinci Resolve to convert the files to prores. Pain in the @rse but the XAVC looks stunning! I mean gorgeous! I’ll post resulting video up here for you to look at 🙂
Just a thought… would Sony Vegas not handle XAVC???
Jay Davis
March 20, 2013 at 9:33 pmI am using Resolve to quickly convert the files from XAVC to ProRes or DNx. Then moving to editorial. I find the trans-code necessary because not all editorial departments are using “up to date” version’s of their NLE. So using these flavors I know they at least can open the files and move on. I then re-conform the edit back in Resolve linking to the 4k XAVC files and do final grade and finishing.
I agree that the XAVC looks really nice. For a very lightweight file it holds up surprisingly well. And on a simple DIT laptop station you can render out dailies fast. I would consider this a nice flavor to work on TV projects and shoot UltraHD.BTW, you need to use the Resolve version above 9.1 and above to support the XAVC native.
Don Mcvey
March 20, 2013 at 9:45 pmThanks for the advice!
Actually tried Resolve but my iMac kept crashing! So I eventually used Avid AMA to convert the files to Prores, then just edited in Pr. I was only shooting 1080p so that worked fine 🙂
Jay Davis
March 21, 2013 at 3:04 amYea Resolve works best when you have a dedicated GPU on board for processing so if your imac is older it probably will struggle. Without at least one extra GPU it can be cranky.
Michael Ricci
March 26, 2013 at 3:16 pmYou’re in CS6? Trying to flip to ProRes? You don’t need content browser as CS6 reads and plays .mxf. If you’d rather have a .mov, do the following.
1) Import complete file structure to Media Encoder and export desired settings.
2) Import complete file structure into a Premiere project with sequence set for XDCAM 422 1080p30 and export to desired settings.Hope I was understanding correctly.
Don Mcvey
March 26, 2013 at 3:45 pmHi Michael,
Was trying to get prores or anything that would work with CS6. XAVC is not supported at all in Pr or Media Encoder. It just crashes. I know it’s .mxf but it’s a different kind of .mxf
