Activity Forums DaVinci Resolve Sony F3 S-Log 10 bit 4:2:2 or Gemini 4:4:4
  • Sony F3 S-Log 10 bit 4:2:2 or Gemini 4:4:4
    Posted by George T. griswold on October 6, 2012 at 2:25 pm
    Hello DaVinci pros…
    I have an upcoming shoot with my F3 and we will shoot S-log to an external recorder. What are the penalties in grading if we use a 10 bit 4:2:2 recorder as opposed to a Convergent Designs Gemini recorder that would be dual link 4:4:4. Obviously the Gemini is better, but the massive DPX files could present a real problem in terms of media management. The material is for a TV spot with food beauty shots and chef interviews. What do you think?
    George Griswold
    New Orleans, LA
    http://www.videonow.info
    Margus Voll replied 13 years, 7 months ago 3 Members · 4 Replies
  • Toby Tomkins
    October 6, 2012 at 6:39 pm
    It’s really not ‘worth’ recording DPX and here’s why;
    The datarate is massive, around 250MB per second, or in Mb terms, 2000Mbps! This likely means huge storage amounts will be needed for the shoot and backup, copying/transferring the files will take AGES and (unless you have a beefy RAID on set/location) you won’t be able to watch the files back in real time. It will also take a long time to transcode the files to a useable edit format (unless you have very fast storage to read from and decent hardware)
    The amount of time and money potentially spent over shooting 10b 422 would be better spent on a decent colourist and more grading time. Hands down.
    The only real limitation would be for green screen/ keying work or extreme secondary colour correction (ie turning a dark pink scarf red while the person is also wearing a red jacket).
    If you have the facilities/equipment and time, shoot your own tests and compare. If not I’d vote for 422 10b over DPX in my opinion.
    Either way good luck with the shoot (-;
    Toby Tomkins
  • Toby Tomkins
    October 6, 2012 at 6:50 pm
    The best format would be ProRes4444 if you can record it! The quality benefits of 444 and less compression without the size of DPX. Or DNxHD 444…
  • George T. griswold
    October 6, 2012 at 6:55 pm
    I saw that the Cinedeck can do that… not sure I can get one locally… still hefty files. This is TV spot after all.
    Thanks for your replies Toby
    George Griswold
    New Orleans, LA
  • Margus Voll
    October 11, 2012 at 12:48 pm
    prores 4444 should be really usable in sense of workflow compared to dpx
    should run on most of the systems and have color data also intact.
    10b 422 would be also fine if you do not want to go extremes in post as pointed before.
    Margus
    https://iconstudios.eu
    DaVinci 9, OSX 10.7.4
    MacPro 5.1 2×2,93 24GB
    GTX 470 / Quadro 4000
    Multibridge 2 Pro
