Activity Forums Sony Cameras Sony EX1-R slow motion
  • Sony EX1-R slow motion
    Posted by Vladimir Philogene on June 12, 2010 at 7:31 pm
    Hi, I just bought the sony ex1-R. I did everything I could to use the slow motion option but I still can’t use it. It’s say “Cannot Proceed”…
    1- I verifyed if my SxS card was inserted and if he was enable to record normal footage with the camera.
    2- My camera is set to 1080 at 30p
    3- I put the slow motion at: 1080 30p and frame Rate at 30.
    What else should I do or where did I do wrong?…
    Tim Hore replied 14 years, 11 months ago 9 Members · 17 Replies
  • 17 Replies
  • Brian Moore
    June 12, 2010 at 9:16 pm
    you cant shoot slow motion at 1080, it has to be at 720.
    so when you so into S&Q Motion, set it to 1280/60p
    that will give you your desired results
  • Craig Seeman
    June 12, 2010 at 9:46 pm
    For example:
    720p24/60
    720p30/60
    The range in 720 is from 1 to 60 frames.
    In 1080 the range of Quick and Slow motion is from 1 to 30 frames.
    So you could slightly slow things down as
    1080p24/30
    but that’s it.
  • Vladimir Philogene
    June 13, 2010 at 4:32 am
    Well I tried everything again, and no results….
    I don’t understand…
  • Rafael Amador
    June 13, 2010 at 11:05 am
    Set the camera at 720p24 or 720p30, depending of the final time-base you want.
    Then go to “S&Q Motion”, set it ON and select “Frame Rate: 60”.
    You will record 60 fps, but the resulting file will play at 24 or 30 fps.
    Rafael
    http://www.nagavideo.com
  • Scot Lenter
    June 14, 2010 at 9:30 pm
    Vladimir,
    It is possible that you have one of the new cheaper SxS cards that does not support overcranking.
    Can you post a picture of the card?
    Scot Lenter
    Midtown Video
    Miami, Florida
    Rental Manager
    Service Manager
    http://www.midtownvideo.com
    scot@midtownvideo.com
    305-669-1117
  • Craig Seeman
    June 14, 2010 at 9:36 pm
    ALL SXS cards support overcranking.
    There are only two kinds SXS and SXS-1 and they BOTH support full overcranking. The only difference is the longevity of the media.
    With latest firmware upgrade, the better SDHC cards support overcranking as well. Such as Sandisk Extreme Class 10.
  • Scot Lenter
    June 14, 2010 at 9:40 pm
    Craig,
    I have successfully over-cranked with SxS-1 but according to my Sony reps they do not support it.
    In fact, I have never had it fail, so I politely disagreed with them during our training. They maintained that this was the case..
    Scot Lenter
    Midtown Video
    Miami, Florida
    Rental Manager
    Service Manager
    305-669-1117
  • Scot Lenter
    June 14, 2010 at 9:45 pm
    Eh..
    You are probably right because I dont see anything on the Sony website with that limitation.
    Maybe my rep was misinformed and I actually won that argument..
    Scot Lenter
    Midtown Video
    Miami, Florida
    Rental Manager
    Service Manager
    305-669-1117
  • Craig Seeman
    I’ve heard otherwise from Sony on that. SxS-1 should maintain the same data rate.
    https://pro.sony.com/bbsc/ssr/product-SBS32G1/
    Sony “SxS-1” was developed to meet demands for an affordable solution to SxS PRO memory cards. The SxS-1 memory card maintains the same shooting capability as SxS PRO as well as high performance and reliability for professional use. The only differentiation between the SxS-1 and SxS Pro Memory card is the reduced number of read/write cycles.
    I’ve been told that includes full overcrank support. Only the life cycle is shorter as I’ve been told and the above implies.
  • Craig Seeman
    June 14, 2010 at 9:48 pm
    Sony will say it’s not supported on the following
    https://pro.sony.com/bbsc/ssr/micro-xdcamexsite/cat-accessories/product-MEADMS01/
    and
    https://pro.sony.com/bbsc/ssr/micro-xdcamexsite/cat-accessories/product-MEADSD01/
    although with most recent firmware it does work but it very much depends on the quality of the flash card used.
