Activity Forums Sony Cameras Sony EX1 external monitoring issues
  • Sony EX1 external monitoring issues
    Posted by Joseph Wilkins on June 8, 2013 at 2:57 am
    So I have a Sony EX1.
    About 2 years ago, the Component out quit giving me a color signal.
    All I can get out of it – regardless of the monitor I plug into is a black and white signal.
    It’s very annoying as it is a studio camera and my clients like to watch in video village.
    So I figured I’d go buy a cable to plug into the HDSDI out port and plug in that way.
    I attached to my same IKAN 7″ monitor that worked fine ( apart from the B&W)… but no image.
    I flipped iLink off and enabled HD and all the steps the manual says to do… nothing. I switched the monitor through the various inputs… nothing.
    I took the EX1 down to my local camera dealer and he plugged it into a monitor… perfect picture immediately without messing with any of the settings.
    So I know the camera is set to output a picture… any idea why my monitor will not display it?
    We even tested with the cable and it worked at the store… so it must be the monitor.
    I think it’s a 720p monitor… not 1080p… but I get a signal in component mode…
    Any help would be greatly received.
    Jw Van der vlies replied 13 years, 2 months ago 3 Members · 10 Replies
  • 10 Replies
  • Jw Van der vlies
    June 9, 2013 at 10:41 am
    Maybe the Y component input can be set on composite also? So that it only ‘sees’ the Y channel, which is black and white.
  • Joseph Wilkins
    June 9, 2013 at 2:29 pm
    Thanks very much…. but I am a dummy… can you please put that into simple terms I can understand and tell me how I can fix it? Thanks so much
  • Jw Van der vlies
    June 9, 2013 at 2:41 pm
    please give me a link of your monitor, there are more ikan 7 inch
  • Joseph Wilkins
    June 9, 2013 at 2:43 pm
    Ikan V8000 HDMI.
    Thanks again
  • Jw Van der vlies
    June 9, 2013 at 2:48 pm
    component and composite are different connections so my theory doesn’t match..
    I’m afraid I can help you. It’s a long shot, but maybe you’ve set the color saturation to zero or something? which means that all the colour is gone
  • Joseph Wilkins
    June 9, 2013 at 2:54 pm
    it is the same on another monitor… it’s not a monitor issue… its in-camera.
    Any ideas on why the Ikan is not displaying the HDSDI out? Does a monitor need to be 1080p to display that? I think my Ikan is only 720p
  • Jw Van der vlies
    June 9, 2013 at 3:03 pm
    your monitor, as i see, does not have hdsdi input.
    your original thread mentions that it’s the monitor!
    out of ideas so far. sorry
  • Michael Palmer
    June 9, 2013 at 3:18 pm
    It seems like you need to convert the HDSDI to HDMI for your monitor, these are both digital signals unlike the component/composite ports.
    https://www.atvresearch.com/HAWK-SDI-HDMI.aspx
    Good Luck
    Michael Palmer
  • Joseph Wilkins
    June 9, 2013 at 3:19 pm
    OH.. maybe thats the problem 😉
    I see a B&C connector… is that not a HDSDI port?
  • Jw Van der vlies
    June 10, 2013 at 11:42 am
    On the camera, the bnc is a hdsdi, on your monitor, i don’t think so.
    M Palmers advice is a good option.
