Activity Forums Audio Sony ECM 77 wiring
  • Sony ECM 77 wiring
    Posted by Dan Waters on December 12, 2019 at 12:37 pm
    Hello. I have two Sony ECM 77B microphones with the 4-pin Hirose connectors that were used with a Sony wireless transmitter.
    I am now using a Saramonic UWmic 9 wireless system and I would like to try using the Sony mics with it. Problem…Saramonic mics use the locking 3.5mm plug.
    Does anyone know first of all, if the Sony lav mic is at all compatible with the Saramonic Transmitter and 2nd, how would I wire a 3.5mm plug to the Sony mic.
    Thanks for any suggestions.
    DMW
    Dan Waters replied 3 years, 3 months ago 3 Members · 6 Replies
  • Jewel Handa
    December 13, 2019 at 4:50 pm
    Hi…Anyone using the PC control software? The rack mount receiver has an Ethernet port for connecting to a Sony application via Windows. Because the controls are done via 2.4Ghz Zigbee mesh network, does that mean all receivers have to be rackmount units if you want contol, or can you just have 1 rack unit and mix with ENG compact receivers and still be able to monitor and control all transmitters via the application?
    https://www.7pcb.com/
  • Ty Ford
    December 15, 2019 at 5:15 pm
    Hello Dan and welcome to the Cow Audio Forum.
    I don’t know the pin outs but I’m pretty sure you can. You just need the right connector soldered on or a converter link cable. Eric Toline made some up for me but I don’t think he’s doing that now. He might be able to help you with the pin out assignments. Failing that, I ‘d reach out to Saramonic support to find that information.
    For technical support support@saramonicusa.com 914.347.3302
    For service and repairs service@saramonicusa.com 914.345.5426
    Regards,
    Ty Ford
    Cow Audio Forum Leader
    Want better production audio?: Ty Ford\’s Audio Bootcamp Field Guide
    Ty Ford Blog: Ty Ford\’s Blog
  • Dan Waters
    December 16, 2019 at 12:32 pm
    Thanks for your information Ty. I have tried reaching out to Saramonic but they have not replied, not yet anyway and it has been over a week.
    I would like to try contacting Eric Toline but I don’t have any contact info for him. It sounds like he may be able to help with the pin out. If I can get that info I’m sure I can go from there.
    Regards
    DMW
  • Ty Ford
    December 16, 2019 at 1:51 pm
    HI Dan,
    Please reach to to me. 410.960.0689
    Ty
  • Ty Ford
    December 16, 2019 at 2:20 pm
    Eric says…
    Open Hirose, look for red or blue wire.
    Ground is and black or braided.
    The other will be white or red that goes to the tip.
    Nothing on the ring.
    Regards,
    Ty
  • Dan Waters
    June 17, 2023 at 11:12 am
    Hello. You helped with a question I had a few years ago…thank you.
    A new question now.
    I’d like to convert an ECM 77 that was a 4 pin Hirose, for use with a Sony UTX-B2 transmitter that uses a locking 3.5 plug. The photo shows
    1 Red, 1 Copper in Clear cover, 1 Copper..no cover, and lastly the shield. Sony plug wiring is very specific, do you have any knowledge?
    Thanks DMW
