Activity › Forums › Broadcasting › sony dvw-m2000p ref. problem
  • sony dvw-m2000p ref. problem
    Posted by Lewis Thomas on July 8, 2009 at 2:13 pm
    Hello,
    I am having a huge problem mastering a program to the Sony DVW-M2000P deck from an Apple Mac with FCP.
    I have the system hooked up using an AJA box and it has a murray pro ppm monitoring the levels.
    I adjust everything so -18db on the decks matches +4db on the ppm, but when I edit to tape the level drops on the deck to -24db. Same thing every time no matter what I do.
    There is nothing at all to help me in the manual it seems, can anyone offer any advice?
    Any responses and ideas are greatly appreciated.
    LT
    Maurice Jansen replied 17 years, 2 months ago 3 Members · 2 Replies
  • Bob Zelin
    July 8, 2009 at 7:36 pm
    post this question on the AJA forum.
    Bob Zelin
  • Maurice Jansen
    July 8, 2009 at 7:49 pm
    hi lewis
    it will help us to help you.
    if you specify the Lineup level in FCP in dBFS and the country you live in.
    deck’s are tweeked differently in some region’s of the globe. next to that
    where are your PPM’s in the system before or behind the deck???
    aren’t you using embedded audio ????
    you say you use murraypro
    as i watched there website your using BBC scale PPM’s ??
    as far as i know (not sure did not use BBC PPM’s that much)
    4 on BBCscale = 0dBu = -20dBFS
    please give us more info
    greet
    Maurice
