Activity Forums VEGAS Pro Sony DVD Architect 5.0b. Chapters not working
  • Sony DVD Architect 5.0b. Chapters not working
    Posted by John Bolton on July 29, 2010 at 2:25 pm
    I have tried many combination but I just can’t get more than one Button to work. .. I will explain.. I make a new project and insert the Video onto the time line…..At a certain point on the time line I add another Chapter so the time line has – 1:Scene/Chapter and further along the timeline – Scene/Chapter 2……..I then add 2 buttons and in the first button properties within the Destination selection box I select the name of the Video and Destination Chapter I select 1:Scene/Chapter
    With Button 2 I do the same except I select Scene/Chapter 2
    If I Preview this it work fine.. However when I burn it to DVD, only Button 2 works ( changes to a HAND on Hover ) Button one does nothing. I have also tried Playlist and added cut and paste the video and called it another name.. So Button 1 use one movie name and button 2 uses the other.. Still only button 2 changes to a hand. In the Preview it works perfect. Any ideas ? Thanks in advance
    John Bolton replied 16 years, 1 month ago 1 Member · 1 Reply
  • John Bolton
    July 30, 2010 at 5:23 pm
    OHhh I have forgot to mention .. After I Burned the DVD I was playing it back in Media Player on the same PC Suite to check it as the DVD Suite is in another room… This is where you can only select the second chapter with the mouse over,,, I then tried it on a DVD player and both buttons work.. Umm I am not sure if it is also supposed to work in Media player . Any idea
